Moving a evo ix without tc and rear diff
Old Feb 26, 2016 | 02:06 AM
Nomad93's Avatar
Hello everyone,
My transfer case and rear diff has been removed to go get rebuilt, that means the car has no axles attached to the wheel hubs and I was wondering if it's okay to move to car around by pushing it from one place to another i.e from the garage onto the recovery truck , when I push the car I can hear faint clicking sounds coming from where I think the wheel hubs are and I wasn't sure if i'm damaging something. my evo is at my home garage now waiting for the diff to come back from sheptrans so will be sitting here for a few months.
And when I do get everything bolted back to the car is there any precautions I should take when starting the car since it would have been sitting for at least 4-5 months now without cranking the engine, I ran into some financial trouble so couldn't send the diff in right away
Thanks for the help,I know this is stupid question to ask but im quite OCD
Old Feb 26, 2016 | 07:47 AM
barneyb's Avatar
According to the FSM you shouldn't even apply vehicle weight to the wheels with the axles removed.
Old Feb 26, 2016 | 09:04 AM
Nomad93's Avatar
Why what could exactly happened? Would the wheel bearings get damaged? So would you think it be a could idea I change all the wheel hubs before I drive again
Old Feb 26, 2016 | 09:24 AM
Klaiceps's Avatar
Interesting. I've seen numerous Evos sitting with their wheels on outside an Evo shop with no engine, transmission, t-case, and axles.
Old Feb 26, 2016 | 09:46 AM
sujinX's Avatar
very interesting indeed. i've seen the same around shops and build threads.
Old Feb 26, 2016 | 09:51 AM
barneyb's Avatar
For the front hub the FSM states, "Do not apply apply pressure to wheel bearing by the vehicle weight to avoid possible damage when the drive shaft nut is loosened." The section for the rear axle has identical wording. So, dunno if this warning just got stuck in or if the wheels fall off.
Old Feb 26, 2016 | 09:57 AM
Nomad93's Avatar
Well since the car is sitting and only being pushed a few meters I don't see how the wheels are going to fall off or anything be damaged I don't know correct me if I'm wrong, but I guess I'll change the hubs just to be safe
Old Feb 26, 2016 | 10:02 AM
Klaiceps's Avatar
You should be fine. None of your wheels are hooked up to the drivetrain. If you're really really really paranoid, get some wheel dollies to help you maneuver your car.
Old Feb 26, 2016 | 11:35 AM
sujinX's Avatar
ok, what the manual is referring to is to prevent wheel bearing damage.
i've done it on multiple cars without fail. i guess its just up to you, i hardly move it far anyways.
Old Feb 26, 2016 | 01:12 PM
The manual states the following word for word here:
Do not apply pressure to wheel bearing by the vehicle weight to avoid possible damage when driveshaft nut is loosened.
Use special tool MB990767 to fix the hub and remove the driveshaft nut.
All that is noting is if the axle nut has been loosened dont sit the car down on its weight as you will be exerting a load into the hub from the loose axle
If the axles are disconnected or removed all will be OK (thats how I read this)
Old Feb 26, 2016 | 01:15 PM
LetsGetThisDone's Avatar
The hubs are pressed together. They can come apart if roll the car around without axles in it. I know this because it happened to one of mine. I was able to cinch it back up with an impact on the axle nut. But it's less than ideal. Put the axles in and torque the axle nuts before moving it around.
Llew
21
Nov 19, 2025 06:38 PM
ChrisO86
Sep 11, 2017 12:13 AM
Mauricio Evo IV
May 20, 2015 09:53 AM
Llew
May 21, 2014 08:43 AM
evo8black
Feb 27, 2013 08:25 PM
