Anti-seize or grease on bolts?
Old Mar 7, 2016 | 07:35 AM
blas4's Avatar
Hi guys,
I had a throttle body gasket leak, replaced that and now bolting back the TB to the intake manifold.
I was wondering, should I use anti-seize on the 4 bolts, or some regular grease, or nothing?
What do you guys recommend and use?
Also, for the Throttle body gasket, do you guys apply a bit of gasket sealer as well, or just slap on the new gasket and bolt it together?
Thanks!
Old Mar 7, 2016 | 07:51 AM
LetsGetThisDone's Avatar
Nothing on the gasket, as long as its new they seal fine. A little bit of anti-seize on the bolts won't hurt anything. Don't use grease; grease will liquefy with heat, drip out, and make a mess.
Old Mar 7, 2016 | 02:46 PM
Jonno99's Avatar
i always do a slight smear of copper eaze on all threads, just to make it easy to unscrew, just don't have it squirting out of the hole when you screw in.
Old Mar 8, 2016 | 06:36 AM
blas4's Avatar
Alright, thanks for the info guys.
weneversleep
Apr 15, 2010 08:46 AM
w8lifter21
26
Feb 11, 2008 11:55 AM
aboh6leenz
Oct 7, 2007 06:23 AM
supravital
Nov 9, 2005 01:38 PM
freedom
22
Jun 10, 2004 05:33 PM
