Accidentally shifted from 4th to 3rd....
Old Mar 11, 2016 | 10:25 AM
ShiftyPenguin's Avatar
I was going back into 5th to cruise and went in 3rd instead =/. I'm used to a stage 2 clutch on a 2000 prelude lol. anyways, how would i check if my rev limiter is turned off?
Old Mar 11, 2016 | 10:33 AM
Pal215's Avatar
It all depends on how the car was tuned. I'm sure you have a rev limiter set, but that won't prevent a mechanical over rev like what happens when going from a high gear to a lower.
Next time you come in to get the car tuned, ask the tuner what he has set the rev limiter to. That will depend on your cam/valve spring combo, among other things.
I wouldn't worry too much about it.
-pal215
Old Mar 11, 2016 | 12:06 PM
llDemonll's Avatar
this. rev limiter wouldn't have helped you one bit here
Old Mar 11, 2016 | 12:15 PM
-pal215
Actually this cars bone stock besides an hks turbo timer, so that being said is it safe to say the rev limiter is on? But you're right i'm more worried about possible valve damage. I drove the car again today for a bit and everything feels fine so cheers to that
Old Mar 11, 2016 | 04:22 PM
RazorLab's Avatar
Originally Posted by Jonno99
You should have the rev limiter to stop you over revving anyway, l
A rev limiter will not stop a mechanical over rev like a gear zing.
Old Mar 11, 2016 | 04:56 PM
Pillock's Avatar
That is correct. You are on your own if you mechanically over rev the motor....ask me how I know lol. OP if you don't hear any strange noises and there were no nasty bits in the fluids that were just changed, I'm guessing you are ok Like someone said, as long as the RPM's didn't go too high you should be fine. The clutch may have slipped enough to save you too if you didn't let it all the way out.
When I money shifted my E36 a year ago on track, I instantly knew it was all bad lol. Tambourine idle wasn't a great sound. Lol she still survived 4 more track days
Old Mar 11, 2016 | 05:00 PM
cleong's Avatar
You should have the rev limiter to stop you over revving anyway, because your new make sure it's not disabled.
The rev limiter is electronic and prevents engine RPMs rising beyond the safe limit. Selecting a wrong gear, however, will result in a mechanical over-rev. (sorry read the prev page and did not realise everyone has already pointed this out)
Old Mar 11, 2016 | 09:54 PM
haha no bueno! Yea i think it's fine, i threw a code today but luckily it turned out to be cylinder 1's spark plug cap wasn't seated all the way. So we clicked that sucker down and were on our way!
Old Mar 14, 2016 | 04:28 PM
Rspence21's Avatar
More than likely, your clutch would have taken the brunt of it to be honest, but it sounds like its probably ok. the 4g63 motor is very strong and most people go with builds that allow over 10k rpms...if it was just a hit third, realized it, shifted out, im willing to bet your A-Okay. as stated before, sounds like a situation where your clutch took the brunt and everything else probably didn't even notice or care(if parts could care) learn to walk before you run good luck and have fun man!
Old Mar 14, 2016 | 05:09 PM
turboed350z's Avatar
its never ideal to have a jump in rpm that roughly, but unless your putting down serious power, i doubt it did damage. listen to idel and rev to 2-3k ish, no strange noise, no valve/piston damage, no problem.
Thatotherguy
13
Oct 11, 2012 05:48 AM
boosted91t
13
Nov 28, 2011 12:31 PM
dtuned
Jun 4, 2009 02:02 PM
