need help AC on my car blows hot air
Old Apr 10, 2016 | 07:52 PM
Evoguy!123's Avatar
ok so all of a sudden my AC stops working, my first though was that my refrigerant was out, but apparently its not, haven't changed it ever since i bought it. i bought a refrigerant to refill it, so I connected it but it was in the middle of the RED color witch is obviously bad, but iv checked my compressor clutch it was working, do i need to flush the system? Do i need to clean any filter or do i have leak?
Old Apr 11, 2016 | 06:42 AM
With the engine running & you press the AC button, do you hear the compressor engage which puts a definite load on the engine?
Is the AC light illuminated? If so, & did you feel the load on the engine?
Possible compressor issue or hopefully just a refrigerant issue? Might be time to visit an AC pro
Old Apr 11, 2016 | 09:39 AM
Evoguy!123's Avatar
Yes i hear it engage when i turn the ac on i dont think is the compressor?
Old Apr 11, 2016 | 09:49 AM
shavkatjon2000's Avatar
ok there could be lots of things low on ac refrigerant possibly noting in the system or its leaking somewhere so i would take it to the shop let them charge with dye they you can figure it out where is it leaking from
Old Apr 11, 2016 | 10:02 AM
Evoguy!123's Avatar
Yea because i checked the gauge that was include of thw refrigerent and it was in the red spot so im guessing its over filled
Old Apr 11, 2016 | 03:12 PM
barneyb's Avatar
I went through this last summer. Drive for a bit with a/c then hot air. Took it to the shop and they found the charge was a little low. I had them pull and replace the refrigerant with the proper amount. Same problem.
Next I replaced the clutch. It was shot. Then I noticed that when I was removing the cap on the low side schrader valve I got a little hiss. So, there was the cause of the low refrigerant. So, back to the shop for two new schrader valves and another recharge.
Lancerfry30
Mar 10, 2017 07:50 AM
1lancer
Lancer Troubleshooting
22
Feb 14, 2015 08:42 AM
NitrousOxide
12
Sep 24, 2010 06:10 PM
Brian Chen
Northwest Region
Jun 13, 2003 04:47 AM
