Weird start/ no start issue ongoing issue. **Help**
Old Apr 13, 2016 | 10:42 PM
turbocheese's Avatar
Hey guys,
Thanks in advanced for reading.
Relevant Mods:
Evo 9
FIC 2150s
Double pumper *new*
FP Black
Built long block
GSC s2 cams
Fuel Lab FPR
Spoolin up COP
Speed density / stock ecu
base map from ts comp
So the here is the issue:
Initial cold start - You have to floor the gas pedal while cranking the car several times for it to start. Once started you can drive for about 10 minutes. After that, once you stop at a light the car will stall and die. Once dead, she does not want to start again. You might have to wait some time then floor the pedal and crank for quite some time because the car wants to start again.
First thing i checked was for boost leaks. Car has a slight one at the TB shaft seals like most cars. Not enough to make the car turn off and not want to start.
I then went ahead and changed the crank and both cam sensors . Issue remained.
Changed the map sensor and iac sensor. Issue remained.
Didnt change the TPS because I am able to log it and see that its working
Originally had a walbro 450 in there, swapped it for a double pumper - issue remained.
Swapped ECU's - Issue remained.
Lost at this point. Need help.
Thanks guys
Old Apr 14, 2016 | 12:21 AM
Evo9"Miss Rose"'s Avatar
Old Apr 14, 2016 | 06:53 AM
turbotaloon95's Avatar
Have you set your idle recently? Maybe you just need to adjust your BISS. I had a similar issue that seemed to go away when I did a proper BISS adjustment. You may need to set idle higher too with your cams. Just a thought.
Old Apr 14, 2016 | 04:46 PM
Swapped in another set of 2150s and issue went away
turbocheese
Apr 13, 2016 11:08 PM
iggypooper
Aug 2, 2012 10:31 AM
evo_soul
Lancer Engine Tech
20
Dec 15, 2009 02:01 PM
JKD
Aug 29, 2009 05:20 PM
e-autosports
Evo 'For Sale' Exterior Styling
42
May 3, 2009 03:37 PM
