CA smog😡
Old Apr 29, 2016 | 07:40 PM
  #31
edsct9a's Avatar
Originally Posted by benIX
my cable is 1.3u i believe. i cant open anything in ecuflash. i plug it in nothing happens. it doesn't recognize my car at all.
I get that I have the same problem that I can't read or write on Ecuflash. So instead I use EvoScan to read and write to the ecu.
Old Apr 29, 2016 | 07:54 PM
  #32
Biggiesacks's Avatar
your not understanding how the process works. You save the rom from your ecu to your computer, modify it, then flash it back to the car. You can read the rom with evoscan, then open it up in ecuflash to make the modifications, save it, and then use evoscan to write it back to the ecu.
Old Apr 29, 2016 | 08:41 PM
  #33
benIX's Avatar
Shouldn't ecu flash recognize my car before I can download the rom?
Thanks
Old Apr 29, 2016 | 09:04 PM
  #34
Thanks
Sorry i thought you had mentioned evoscan was working. If so evoscan has the ability to read, and write the ecu as well. By recognize your car, do you mean it cannot open your rom?
Old Apr 29, 2016 | 09:44 PM
  #35
benIX's Avatar
No every time i plug it in in the ecuflash it says No vehicle interface
Old Apr 29, 2016 | 09:51 PM
  #36
Do you have evoscan? If so can you connect to your ecu with it?
Old Apr 30, 2016 | 09:10 AM
  #37
benIX's Avatar
I don't have evom can. But if it'll work I'll buy it.
Old Apr 30, 2016 | 09:30 AM
  #38
edsct9a's Avatar
Uninstall whatever Ecuflash you have and delete the main folder usually in program files if the uninstall doesn't get rid of it. Then install this older version of Ecuflash: http://evoecu.logic.net/mirror/ecufl..._setup129a.exe
If it is able to read your ecu then your cable is fine and you will be able to use EvoScan to read and write.
Old Apr 30, 2016 | 04:16 PM
  #39
benIX's Avatar
Does anybody know why the video in the thread doesn't work? If anybody has a video on this I would really appreciate it. Thanks
https://www.evolutionm.net/forums/ec...us-mrfred.html
Old May 1, 2016 | 12:34 PM
  #40
benIX's Avatar
Ok so I'm getting really frustrated ��. I bought evoscan in a hope that it would recognize my car. Well I was wrong ��. For some reason it still doesn't recognize my car. I remember when I first got the cable it use to read my car no problem with ecu flash. Now it's being stubborn. This would be the first time since I tuned the car that I'm trying to connect to the ecu and it wouldn't work. since I bought the cable it would be the secound time. So the first time when I hooked up before the tune it worked fine. Please Help ��������
Old May 1, 2016 | 12:41 PM
  #41
RazorLab's Avatar
Sounds like a driver issue. Un-install all Tactrix drivers and reinstall. Un-install Ecuflash and associated files and do a clean install of the application.
Also, you don't use Evoscan to tune, it's for data logging.
Old May 1, 2016 | 01:01 PM
  #42
benIX's Avatar
I uninstalled and reinstalled ecu flash like 10 times I have the 1.3u cable which it doesn't recognize
I've I uninstalled all the USB ports and reinstalled them still every time I plug the USB in it says it didn't install or it says Windows can't recognize the input
Old May 1, 2016 | 03:37 PM
  #43
Do you have a different computer you can try it on? At this point its sounding like your cable might be toast, but the only way to really tell is to try it on a different PC. If it still wont recognize the cable then you will need to replace it.
Old May 1, 2016 | 03:41 PM
  #44
benIX's Avatar
What can cause the cable to go bad? I've only used it twice lol.
I do have Windows 7 professional could that be the reason?
Old May 1, 2016 | 03:49 PM
  #45
ive used it on all versions of windows with no issues. I did have a 1.3u cable go bad on me. Inside the flash cable had rubbed through its insulation and was shorting. I replaced it with a 2.0 and decided to tear the thing apart to try and fix it. Even after repairing the insulation it was still toast. This happened after many times of use though.
