Help. Tricks to un-pinning conmectors?!?!
Old May 8, 2016 | 02:08 PM
JRally's Avatar
I have my motor out so while its out I am cleaning up my wiring harness. I've breezed through all of the sensor connectors and such easily, but these connectors the come thru the driver side kick panel grommet are kicking my ***.
Obviously the standard pull the lock tab back and slide the pin out method isn't quite doing it. Any tips on how to accomplish this?
Attached Thumbnails Help. Tricks to un-pinning conmectors?!?!-20160508_135754.jpg   Help. Tricks to un-pinning conmectors?!?!-20160508_135801.jpg
Old May 8, 2016 | 02:23 PM
JRally's Avatar
Nevermind, figured it out
Old May 8, 2016 | 03:32 PM
Code Monkey's Avatar
Care to share how you did it?
Old May 10, 2016 | 12:03 AM
Boost Demon's Avatar
Veteran: Air Force
May be a similar concept to removing a DSM pin with the way the clips are positioned in the plug to retained in the pin.
Old May 10, 2016 | 12:26 PM
JRally's Avatar
There was a little lock strip you had to pull on the connectors, once I did that it was fairly easy.
EVO GOES VROOM
Mar 19, 2016 10:37 AM
Ghost-Eyes
May 27, 2013 04:54 AM
ihockey1
Jul 8, 2012 11:16 AM
Drooke
South Region
Oct 22, 2008 09:15 PM
