Wing won't come off
Old May 9, 2016 | 12:01 AM
mr.k's Avatar
Wing won't come off
Hey all, just got an 05 evo the other day and it's awesome. I tried to take the wing off because the clear coat is fading and I got all nuts and bolts off minus the driver side bolt towards the rear of the car. The bolt is super rusty and just spins but doesn't loosen. I got all of the glue off too so I'm positive this is the culprit to the wing not coming off..
Has anyone had experience with their wing being stuck on because of stripped threads? I tired to look around and I haven't found anything. I don't care if I have to cut the bolt off, I'm more worried about messing up my trunk paint.
Any help is much appreciated
Old May 9, 2016 | 03:20 AM
Turndown's Avatar
Veteran: Army
The stud is probably rotted out inside from moisture... https://www.evolutionm.net/forums/ev...y-bracket.html
That's a thread on fixing the bracket once you get the wing off. Good luck!
Old May 9, 2016 | 07:23 AM
mr.k's Avatar
Thanks for that. Any idea how you would go about taking off the wing if that stud is rotted out?
Old May 9, 2016 | 01:15 PM
Turndown's Avatar
Veteran: Army
I would probably hack it off with a dremel and cutoff wheel. Shouldn't take but a minute to buzz it in half
Old May 12, 2016 | 11:35 AM
thestig0711's Avatar
Try using fishing line. Mine had glue holding it as well as the bolts. U can also use thin rope or floss.
Old May 12, 2016 | 04:04 PM
Evox2008xove's Avatar
fishing line and a heat gun....
rodent
17
Jul 5, 2009 12:38 PM
EriCS
Nov 11, 2008 12:15 PM
badbrain
Jun 17, 2006 11:28 AM
AlwaysinBoost
Dec 5, 2004 08:32 PM
Casper
Nov 25, 2004 11:34 PM
