Evo 9 gates water pump
Old Jun 22, 2016 | 08:18 PM
Lombardi23's Avatar
I'm looking for a link for the Evo 9 water pump from gates everything is showing for a 03 to 05 evo. But when I go on mapperformance for timing belt kit the water pump option shows one for a 8 and one for the 9. Although can't find a link for the 9 pump itself.
Old Jun 22, 2016 | 08:45 PM
LetsGetThisDone's Avatar
The gates water pump is EVO 8 only. Those other part numbers are OEM parts. Gates doesn't make a 9 water pump.
Old Jun 22, 2016 | 09:44 PM
Acuality's Avatar
+1 to above,
you can use an evo 8 pump on a 9, the alternator bracket is different to my understanding, so you will end up using 1 less bolt or something like that, it works fine though many evo 9 owners have done it that way so they dont have to spend so much on OEM.
Old Jun 23, 2016 | 12:48 AM
MRadjahoe's Avatar
^^^^^^correct
Old Jun 23, 2016 | 08:16 AM
uneekvisions's Avatar
There are plenty of guys that do run the gates pump on their IXs. Despite that I just replaced the water pump in my IX. I went OEM cause my OCD would have bothered me about the missing bolt/bracket combo. Got mine from extremepsi.com for $229 shipped.
Old Jun 26, 2016 | 08:17 AM
Grimgrak's Avatar
Too bad the evo9 oem replacement pumps leak.
Old Jun 27, 2016 | 08:54 PM
Syringe's Avatar
I recently did my timing belt and put a GMB (148-2000) pump on it.. and so far no issues. the only thing is, it doesn't have 1 hole for a bolt on a bracket with 4.. not critical to me.
honki24
Sep 15, 2016 09:05 PM
Jmills
25
Apr 17, 2015 06:58 AM
EvO-LOui
Feb 18, 2015 10:38 AM
turbodsm420
Feb 22, 2014 05:32 PM
yenny
Sep 22, 2012 12:47 PM
