Where to place RTV sealant on valve cover ?
Old Aug 3, 2017 | 06:59 PM
Bmurray's Avatar
I apologize for bringing this thread back, but rather than starting a new thread, I figured i'd ask.. can anyone tell me the difference between these 2 gaskets from advanced? they both say they fit my evo 9, but they have different parts #s. want to make sure i get the correct one.
Old Aug 3, 2017 | 09:47 PM
tauro91's Avatar
I wouldn't buy anything but Oem, I have brand new Oem gaskets for the evo 9, both valve gasket and spark wells gaskets, that I can ship out right away, if interested let me know
Old Dec 7, 2020 | 03:28 PM
kyoo's Avatar
Heres the manual instructions:
@MinusPrevious in that top image, that sealant is in addition the valve cover gasket? does the sealant sit between the valve cover and gasket or gasket & head?
Old Dec 7, 2020 | 03:42 PM
Hey Sam
Just from reading the details, it appears the sealant gets applied directly to the valve cover, in those areas, then the gasket is to placed before the sealant hardens. So, Yes, looks like Mitsu wanted double protection in those areas
Old Dec 7, 2020 | 03:46 PM
kyoo's Avatar
Hey Sam
so front and back into the valve cover, and then those 6 spots? then gasket, then put it on the car
Old Dec 7, 2020 | 03:58 PM
Keep in mind, i have not personally done this. To me, it looks like the sealant goes on the 6 spots only & then install the gasket prior to the sealant hardening. I wouldnt be surprised if most members dont even install the sealant
Old Dec 7, 2020 | 04:12 PM
kyoo's Avatar
in the top image it looks like it goes on the front and back too? or is that for something else
Old Dec 7, 2020 | 04:40 PM
Yes, it certainly looks like Mitsu wanted that sealant on the 4 flat surfaces that mate w/the head, front & back (intake & exhaust side)
Also, just to confirm the cam radius's need the sealant as well. Tried uploading the full 11B manual but its 1mb too large
Old Dec 7, 2020 | 04:44 PM
V.8MR's Avatar
For what its worth I only used Mitsubond on the 1/2 moon insert in the head. Did not use any on the valve cover at all and with all new rubber gasket and the 4 rubber plug inserts it does not leak at all.
Old Dec 7, 2020 | 04:47 PM
Yep, that what i figured some of us were doing. The OEM is always looking for the optimum in prevention to reduce warranties. I would still follow the manual for that added protection
hutch959's Avatar
if i remember correctly... the evo 9 manual does not call for it in the front and rear... only at the cam caps
Old Dec 7, 2020 | 05:09 PM
The manual images loaded are from the 2006 manual
Old Dec 7, 2020 | 07:50 PM
kyoo's Avatar
right that's why i was confused, some people say just those six spots/a few spots, and the image above, with the asterisk of TSB Revision, includes some at the front and back of the valve cover...
Old Dec 7, 2020 | 09:30 PM
kyoo's Avatar
no sealant for the spark plug gaskets, i assume?
Old Dec 8, 2020 | 01:44 PM
V.8MR's Avatar
No. And again you'd be fine running no sealant anyway provided the cover is torqued down properly and checked periodically.
