Where to place RTV sealant on valve cover ?
Old Dec 11, 2020 | 09:01 AM
  #46
XSivPSI's Avatar
I put a dab on each of the cam cap corners ~10 years ago when I did my first timing belt job and haven't used any since, and its been off a half dozen times, looks a little ragged in some areas but never leaks. Still the original early 2003 build gasket.
Old Dec 14, 2020 | 04:57 AM
  #47
Apex Hunter's Avatar
I always figured that the RTV in the VC rail valley was only to ensure that the gasket doesn't fall out when you flip the VC over to re-install. I don't think that has anything to do with oil control.
The RTV on the 6 spots yes, oil control, and agreed that it's not absolutely necessary. I do it anyway, because unlikely or not it's an easy enough insurance policy. Easy to apply, easy to remove. Don't need much. I usually apply it directly to the head rather than applying to the corners of the gasket, mostly just because that's how i've always done it over the years.
Old Dec 14, 2020 | 04:29 PM
  #48
hutch959's Avatar
i would agree.
Old Dec 15, 2020 | 11:24 AM
  #49
Kevin.'s Avatar
Where can I download that mitsu manual?
Old Dec 15, 2020 | 11:41 AM
  #50
kaj's Avatar
kaj
I just came in to see how such a simple task ends up with 50 replies.
Yah..Im bored at home, with a cold.
Old Dec 15, 2020 | 11:44 AM
  #51
kaj's Avatar
kaj
https://evoscan.com/vehicle-manuals
Old Dec 15, 2020 | 11:45 AM
  #52
kyoo's Avatar
lol you never know, may help someone in the future.
Old Dec 17, 2020 | 04:45 AM
  #53
Lol....same
Old Dec 19, 2020 | 02:39 PM
  #54
kyoo's Avatar
thanks for the input all, was helpful. all wrapped up - getting the valve cover to line back up was surprisingly easy, and the only thing I noted about the process was that I needed make a few passes (at the same torque) on all the bolts to make sure everything settles evenly.
i'll let it cure for a day before i take a spin and then a quick oil change as well. need to get the car up anyway to flush the trans and t-case
jd888jd
Evo X How Tos / Installations
Feb 16, 2009 09:39 PM
eyekyu
Mar 31, 2008 08:18 AM
scherejs
Aug 4, 2005 01:29 AM
