Springs or coilovers?
If youre DD'ing, staying w/OEM struts is your best bet. Run them w/some Swift springs & youre set. Less fuss, better corrosion protection, more durable & less chance of seal failure
My background is more track day performance parts so we tend to recommend Swift / GTWorxs springs
Again, if youre just DD'ng, & the spring drop is not too aggressive, im sure the Teins will be OK (there are certainly plenty of EvOs running them)
The problem with lower springs, is their spring rates are still very soft. For example Swift spec-r evo springs are 6.5kg front/6.8kg rear. http://www.swiftsprings.net/products...ct/spec-r.html
While a ton of people have found good results on 10-12kg springs on street/track coilover setups.
Looks like everyone has a little different opinion, sounds a little biased 😜. Whats the major difference between each other besides one is adjustable? Its going to be daily driven and if it ever see's a track its going to be a straight line.
