Low compression unlike anything i've seen
Old Nov 3, 2016 | 10:16 PM
LetsGetThisDone's Avatar
Originally Posted by 4b11slayer
If you had leak down out of valves.
A you weren't on true dtc.
B the valve seals,guides,seat need to be inspected.
Not visually but by a machine shop.
Valve seals have nothing to do with cylinder leak down. Guides do, to a point, but they have to be severely worn to cause the valve to sit in the seat crooked. 99.9% of the time, valve leakage is cause by a damaged seat or valve.
Originally Posted by Mobsters
to work properly the GSC zero tick lifters need valve stem projection to be inside oem limits.
I had this same problem with my engine and GSC lifters.
I don't think this is the problem since the motor was fine for 5k miles.
Old Nov 4, 2016 | 08:59 AM
4b11slayer's Avatar
OOPS I thought worn valve stem seals could cause a leak down reading.
Old Nov 7, 2016 | 03:17 PM
RightSaid fred's Avatar
The pistons need to come out to check for damage.
As in broken ringlands
Old Nov 10, 2016 | 07:48 AM
ISPEVO8's Avatar
i know its been a while since i updated this but mobsters was correct the valves were not seating fully when the cams were installed thus the reason for low compression. a vacuum test on each cylinder also confirmed it that the intake was not sealing. also the pistons were actually installed backwards (just my kind of luck) the machine shop rotated them as well as inspecting the rings and bearings. thankfully everything looked good. the car is currently getting a custom catch can setup new ID1300 injectors and retune. i'll post up the results when everything is said and done.
Old Feb 27, 2017 | 07:01 PM
Tommyfacekicker's Avatar
Wow that would've pissed me off. I would put the shop on blast. That coulda sent your engine to the junk yard.
Jonno99
Apr 26, 2015 08:26 PM
dambikeracer
57
Mar 14, 2010 07:43 PM
Sievers
19
Mar 27, 2009 06:03 AM
tonykart125
Northeast Region
10
Dec 4, 2008 03:46 PM
Claudius
19
Aug 4, 2002 04:50 AM
