Tire Rubbing, wheel offset suggestions?
Old Nov 23, 2016 | 09:26 AM
Originally Posted by kyoo
Minus,
Can you help me understand - when looking at two wheels, 17x9 +25 and 17x9.5 +32, as far as I can tell it sounds like from owners the 17x9.5 will actually fit better than the 17x9 +25, on the same tires. How does that work? Or is that not right? 0.5" is about 13mm, so let's say half of it contributes to the "outside" part - 6.5mm. so I gain 7mm pushing the wheel back "in" with the 17x9.5, and I lose 6.5mm pushing the wheel out based on the width of the wheel itself. isn't that going to be nearly a wash?
I'm on the stock 17x8 BBS wheels right now on 245/45-17, and I barely have any space between the coilover springs and the tire itself. How does that work?
Your stockers are +38, so of course they will sit further inboard & closer to the coilover
Regarding the +25 vs +32
Its a bit of a wash. The +32 is certainly a better EvO offset but the 9.5" exaggerates the offset making it similar to the +25
Here's the overlay which shows they are both similar w/the slight stretch on the 9.5" wheel
Joe
Old Nov 23, 2016 | 09:30 AM
kyoo's Avatar
Joe
awesome. have I told you I loved you lately??
so I was debating with 17x9 +25 vs 17x9.5 +32 with the wedssport tc105ns. as far as I can tell from your diagram, no real reason not to go 17x9.5
Old Nov 23, 2016 | 09:43 AM
LOL, Brotherly love your way as well
Either way, they both fitup similarly, but the 9.5" gives you more tire options
Old Nov 23, 2016 | 09:45 AM
kyoo's Avatar
yup, that's what i'll go with! I've got a shop that does rolls, I'm assuming i'll still need to roll the front and rear a bit, based on this pics in this thread:
https://www.evolutionm.net/forums/sa...era-zii-s.html
dunlops def run wider than the re71r, but still will be close. hopefully it clears everything! may have to adjust the heights on my ohlins, see if I can run a tiny bit more camber etc though I'm sure suspension wise I should clear. sometimes hard to tell how it all moves under extreme loads though
KFC-AWD
Mar 19, 2015 05:16 PM
urbanknight
41
Jan 11, 2014 02:58 PM
PSIcho
Jun 16, 2008 11:46 AM
shinnster
Apr 22, 2006 01:57 AM
fletch
May 3, 2005 08:38 PM
