Ecu reset & mbc question
Old Nov 17, 2016 | 09:49 AM
2rbolag's Avatar
Is re-adjusting the mbc necessary after resetting the ecu? Basically, adjusting it the same way when initially installed (no boost and progressively increase)
Old Nov 17, 2016 | 11:57 AM
gsrboi80's Avatar
No
Old Nov 18, 2016 | 07:55 AM
llDemonll's Avatar
you shouldn't be adjusting the MBC at all. Get a tune, let the tuner set it, dont ever touch it.
Old Nov 18, 2016 | 07:58 AM
2rbolag's Avatar
The car is tuned...
Old Nov 18, 2016 | 10:36 AM
Biggiesacks's Avatar
Originally Posted by 2rbolag
The car is tuned...
so what do you mean by resetting the ecu? Just powering it off and back on? Because if thats the case, no you don't need to do anything.
Old Nov 18, 2016 | 11:24 AM
2rbolag's Avatar
I had to do something by resetting the ecu (both terminals disconnected for an extended period of time) I was asking if the mbc has to be readjusted just like when doing so when initially setting one up (dial mbc to zero boost, put in third and progressively dial boost to desired level)
Old Nov 18, 2016 | 02:36 PM
barneyb's Avatar
Still no.
Old Nov 18, 2016 | 03:24 PM
4b11slayer's Avatar
Its a MANUAL boost controller so not even related to battery
AlDim
May 18, 2014 07:02 PM
EvolutionIXMR06
Jul 2, 2013 10:17 AM
recompile
Mar 26, 2007 04:28 AM
EvoRs
Apr 30, 2005 05:01 PM
morningstar908
Apr 12, 2004 04:01 AM
