Timing belt rubbing/making a sound after changing it.
Old Dec 14, 2016 | 03:47 PM
  #31
Evo47's Avatar
Good news. I think I have pinpointed the ticking sound. It seems to be the idler pulley, the one that sits by the timing tensioner pulley. I used the stethoscope and the ticking sound was on point. It could be bad or for all I know there might be something stuck behind it. Time to tear it off and see what I'm dealing with. I'll report with results in a day or two.
Old Dec 14, 2016 | 04:25 PM
  #32
Evo47's Avatar
Originally Posted by subivsevo
Same
Yours is also the pulley? Howd you identify it?
Old Dec 14, 2016 | 10:48 PM
  #33
silverevo05's Avatar
Keep us posted
Old Dec 16, 2016 | 06:48 PM
  #34
Evo47's Avatar
Changed the timing belt idler pulley, still getting some kind of sound. It doesn't seem to be as loud anymore, but it might just be in my head. Still looking for a solution.
Old Jan 27, 2020 | 11:58 PM
  #35
SimonE7's Avatar
hi evo47
please share remedy that solved the timing belt area unusual sound.
thank you
Old Feb 24, 2020 | 02:09 AM
  #36
Michael Jensen's Avatar
Originally Posted by SimonE7
hi evo47
thank you
A too tight timing belt will make an Strange rubbing sound.
Old Mar 4, 2020 | 03:21 PM
  #37
bo0sted4g63's Avatar
Originally Posted by Evo47
Ruled out bad compression. Getting a solid 150-155 compression across all 4 cylinders. Changed the plugs but still no change. Really listened to the noise and confirmed its not coming from the head, so that eliminates the lifters and valves being faulty. It is louder towards the lower part of the engine, around the alternator/crank/water pump area. Are there any places that something may go loose and start vibrating? Or maybe it could be a bad oil pump? How do i check if the oil pump is indeed bad? Not getting any CEL's so i doubt it could be that. I have a tatrix cable and evoscan, What irregulaties should i look for when i log it?
If its your oil pump you will start losing pressure. Do you have any oil leaks around that area?
anthonypazsd
135
Apr 2, 2026 12:56 PM
Evo47
Dec 14, 2016 08:13 AM
Delux247
10
Nov 28, 2012 09:28 AM
PSG Evo
16
Feb 6, 2011 09:28 AM
anthonypazsd
Jan 31, 2010 03:01 AM
