Can I/Should I rebuild an engine myself?
Old Dec 30, 2016 | 05:55 PM
  #31
4b11slayer's Avatar
Originally Posted by Evo47
Understood. Ill look into instruction manuals so I know exactly how to place the rings.
None of it is rocket science man.
Actually its all a simple task,
Measure here measure there.
You can use the ring end gap postion straight from the Mitsubishi books.
Quote me if im wrong but the Shop manual can be followed for ring end gap positions?
Old Dec 30, 2016 | 06:23 PM
  #32
kaj's Avatar
kaj
Yes. It's all I used to build mine.
http://evoscan.com/vehicle-manuals
Old Dec 30, 2016 | 06:25 PM
  #33
Heres the procedure from the Mitsu manual
Old Jan 4, 2017 | 12:22 AM
  #34
Jonno99's Avatar
I'd have a go at rebuilding mine when it comes time, but instead of just getting it back to OEM spec, the money I would save in labour I would put towards a 2.2 stroker kit, that way I'd get a new set of pistons, rings, conrods and crank to put in it in the kit. Maybe cams and injectors just to finish it off, do the whole thing once and do it good.
Old Jan 4, 2017 | 07:53 AM
  #35
kaj's Avatar
kaj
I did OEM because I don't have the resources to measure and correct ptw and other clearances. OEM was an easy fit. If you have the tools and skills needed to put it together, i say go for it. I would have.
Old Jan 4, 2017 | 07:55 AM
  #36
4b11slayer's Avatar
I have my machine shop do ptw,hone,deck.
Then you assemble
Old Jan 4, 2017 | 09:57 AM
  #37
lonestarr20's Avatar
Out of curiosity, how much are evo 8 piston & rods worth in excellent condition ?
Old Jan 4, 2017 | 08:58 PM
  #38
4b11slayer's Avatar
H beams 300
I beams 600
Forged pistons 400
Old Jan 4, 2017 | 09:31 PM
  #39
kaj's Avatar
kaj
I think I've seen them listed @ $100.
Old Jan 5, 2017 | 10:07 PM
  #40
All 4 in excellent condition, 100 wow.
Times Are Hard, I'll post pics tomorrow!
Old Jan 6, 2017 | 08:32 AM
  #41
kaj's Avatar
kaj
I'm literally the only person I've known that has purchased OEM stuff for a rebuild LOL. Pistons, rods, and cams never sell for anything worthwhile, really. IF they sell, it takes forever. I have a set of OEM and Greddy cams that have been on my shelf for three years
Everyone wants the fancy stuff.
Old Jan 6, 2017 | 03:44 PM
  #42
Here they are
Old Jan 6, 2017 | 04:01 PM
  #43
RazorLab's Avatar
I see fred is still being a ***. How is he not banned yet.
Old Jan 21, 2017 | 11:00 PM
  #44
Evo47's Avatar
Little update. Purchased ACL bearings, rings, and a new oem gasket set, now waiting for everything to arrive. Should I have went with King bearings instead? I did a lot of reading on the two brands and couldn't decide. They both worked good but there were 1-2 people on each side that had bad experiences. Also, i can't seem to find the main/rod clearance specs in any mitsu manual. What should the numbers be at? .002 for main and .0025 for rod is what I've read from other posts, is that about right? Clearance doesn't worry my too much, everything was in surprisingly good shape when i pulled it apart. But I still want to check everything just to be safe.
Was thinking about building another block I had, but I need to bore the cylinders. Might as well do a full build with it. But that's a project for another time, first want to try out a stock rebuild.
MarkN1689
12
Oct 28, 2006 08:18 PM
Ispool4u
Mid-Atlantic Region
Nov 13, 2005 08:40 PM
dmans_evo
May 5, 2004 06:03 AM
2003specv
15
Dec 17, 2003 01:22 AM
BahnFIRE
10
Oct 2, 2003 03:36 PM
