Doing maintenance need advice
Old Jan 10, 2017 | 11:03 AM
Jovan Caro's Avatar
My evo 8 has about 177k was going to replace the water pump n timing belt wanted some advice should I replace the oil pump or just the seal for now. going to possibly be rebuilding the engine later on this year also was going to replace the tensioner,idler pulley,balancer,balance belt,Timinig belt
Old Jan 10, 2017 | 11:22 AM
4b11slayer's Avatar
t belt
balance belt
idler pulleys
hydro tensioner.
water pump and oil pump can stay unless they are leaking.
Old Jan 10, 2017 | 12:42 PM
Jovan Caro's Avatar
Ok looking Also to replace the clutch starting to slip not gonna do anything performance for awhile so would you recommend a act clutch disc and an exedy pressure plate I've read something about to much bite on a stock motor
Old Jan 10, 2017 | 03:49 PM
DeeEvo's Avatar
I would just buy a stock clutch since you don't plan on modding it right away.
You don't want some race clutch put on a relatively stock car.
Old Jan 10, 2017 | 08:56 PM
4b11slayer's Avatar
You should keep act with act and exedy with exedy for quality purposes.
Slap a act hdss in it and you will be ok for a while.
Your gonna eat a stock clutch
Old Jan 10, 2017 | 09:04 PM
Jovan Caro's Avatar
Thanks for the info much appreciated
Mbrovt
May 12, 2018 10:00 AM
Seansan
Mar 27, 2016 06:26 PM
tattooed_4b11
Aug 3, 2015 03:56 PM
04Evo851374
May 17, 2011 11:38 PM
Dus10
Jan 28, 2006 05:27 PM
