Wont start
Old Jan 10, 2017 | 03:27 AM
Jseda845's Avatar
Wont start
Anybody else having problems starting your car when it's below 20 out? Battery is in trunk idk if that makes a difference. It's really annoying having to jump it everyday. The battery is less then a year old.
Old Jan 10, 2017 | 03:32 AM
Jseda845's Avatar
Forgot to mention it has S2 cams and I'm really thinking about taking them out if that's the problem
Old Jan 10, 2017 | 07:02 AM
sagravtj's Avatar
Hard start due to low battery voltage
My battery voltage gets low at freezing temperatures. I bought a trickle charger and that solved my problem.
Old Jan 10, 2017 | 07:11 AM
llDemonll's Avatar
low CCA, cold temperatures, thick oil, cams
all those will contribute to the same issue
what gauge wire are you running from the battery to the front of the car?
Old Jan 10, 2017 | 06:06 PM
Jseda845's Avatar
6 gauge. 600 cca
Old Jan 10, 2017 | 11:00 PM
4b11slayer's Avatar
Maybe swapping the battery for a agm style.
Old Jan 11, 2017 | 08:21 AM
llDemonll's Avatar
Originally Posted by Jseda845
6 gauge. 600 cca
this could be part of your issue, but i doubt it. usually best to run as large of a cable as you can. hopefully that's a full copper core wire as opposed to copper-clad aluminum
ca18hatch24
Jul 25, 2014 02:28 PM
geevolution
Dec 31, 2009 05:31 PM
iziegsx
Jun 18, 2008 08:02 PM
LancerOzRally35
Lancer Troubleshooting
13
Dec 6, 2003 07:20 AM
Sean
Aug 22, 2003 03:57 PM
