Not going into 2nd gear !?
Old Jan 30, 2017 | 08:04 AM
silverevo05's Avatar
My car seems to not want to go into second gear unless I am making a turn then go into 2nd. If I drive straight it doesn't want to go into 2nd without some force.
All other gears are fine.
Just did a clutch job, all OEM parts about 1.5 years ago and less than 1k miles ago.
Old Apr 19, 2017 | 08:40 PM
supak1111's Avatar
Thats really add, did you connect the shift linkage correctly on top of the transmission? I would double check, make sure its not lose and that everything is how it was when you took it off.
__________________________________________________ _
03 Evo 8, - Manley forged crank - Manley rods - Weipco pistons - ACT stage 2 full face clutch - ACT flywheel - Millimeter oversized titanium exhaust valves - gates blue timing belt - AMS balance shaft delete - Garrett gt3076r turbo - Peak boost turbo manifold - AMS fuel rail - Larger intercooler - Large AMS oil cooler - Custom oil cooler high flow duct - 255lph walbro pump - 780cc precision injectors - Tial open dump wastegate - 3 inch turbo back exhaust - Sard r2d2 BOV... How it all makes me feel? ��
★★ Signature: ™007-License-Plate-Hide-Gadget by: www.HideLicensePlate.com ™★★
silverevo05
10
Sep 5, 2018 03:20 PM
silverevo05
Jul 20, 2015 01:05 PM
killthelights14
19
Aug 12, 2008 04:33 PM
atomicapples
41
Oct 25, 2006 02:56 PM
