Not going into gear 2nd
Old Apr 12, 2018 | 02:15 PM
silverevo05's Avatar
I've had this problem since around since installing a new OEM clutch with OEM fluids etc.
I have trouble going into 2nd. No grinds etc, just wont go into second sometimes. Doesnt matter if its warmed up or not.
Old Apr 12, 2018 | 03:49 PM
user 466457's Avatar
How many miles are on the transmission? Was the clutch pedal adjusted to full travel? DIY or shop?
Old Apr 13, 2018 | 09:02 AM
Shop,
24k miles on previous OE clutch,
per the mech, the clutch pedal was adjusted
Old Apr 13, 2018 | 09:35 PM
2006EvoIXer's Avatar
My guess is your cables need adjustment at the transmission. How long ago did shop install your clutch? Maybe they can adjust cable.
Old Apr 19, 2018 | 07:41 PM
I’ll check. Any particular spot?
Old Apr 19, 2018 | 10:18 PM
Remove your battery and look at all the mounting setup. Make sure everything was reinstalled right. There is very little to adjust (just slack).
Old Apr 23, 2018 | 09:34 AM
Checked and everything looks good under the hood. Don’t know what else to look for
Old Apr 23, 2018 | 12:50 PM
This is happening in only 2nd gear?
Old Apr 23, 2018 | 12:53 PM
Get to your clutch slave cylinder and push the piston back into cylinder as hard as you can. Does it slowly go back in or is it solid and won't retract at all?
Old Sep 3, 2018 | 10:02 PM
Pretty Hard to push in and kicks out quite fast
Old Sep 5, 2018 | 03:20 PM
ANy suggestions??
silverevo05
Apr 19, 2017 08:40 PM
silverevo05
Jul 20, 2015 01:05 PM
killthelights14
19
Aug 12, 2008 04:33 PM
atomicapples
41
Oct 25, 2006 02:56 PM
