Evo 8 stripped head bolt
Old Feb 10, 2017 | 08:36 PM
DeeEvo's Avatar
So long story short, my turbo oil feed line (head side) where the banjo bolt connects is stripped. I removed the bolt and it had the aluminum head in 2-3 threads fully.
I tried to put it back in to see if it would tighten down and it just kept turning. After cleaning the bolt.
So looking at my options.... I could pull the head, and heli coil it, but that is a lot of work
Or.. purchase one of these and hope the new bolt that blocks that area can grab some threads.
http://www.forcedperformance.net/mer...Lancer-TurboHW
https://www.maperformance.com/produc...ubishi-evo-8-9
Thoughts?
Old Feb 11, 2017 | 07:27 AM
IzzyRS's Avatar
The easy way out would be using the MAP oil feed line. They include a bolt to block the head feed, you just might have to JB Weld it in there (and fix it properly whenever you pull the head). I am running the MAP feed line, no issues.
Old Feb 11, 2017 | 11:59 PM
4b11slayer's Avatar
^^ this.
Or retap it next size up and order new banjo
Old Feb 12, 2017 | 06:17 AM
DeeEvo's Avatar
Thanks for responses. Ordered the MAP kit and will JB weld it until head comes off.
Old Feb 12, 2017 | 07:00 AM
4b11slayer's Avatar
Oil other thing i can say is prep the area good and allow full dry time for best results
Old Feb 17, 2017 | 03:57 PM
DeeEvo's Avatar
Installed kit today and everything went well. Drove it around the block a few times and rev'd to 5k, let run for probably 10 minutes and NO LEAKS!
I did not end up using the 2 rubber orings that came with the kit or the oil filter gasket thing ? Maybe they are for different purposes?
Either that or I messed up...
dudical26
51
Sep 9, 2012 02:02 PM
steevo 8
Apr 6, 2008 06:53 AM
CrackerJackToy
10
Jun 30, 2007 07:27 AM
walkedu
21
Dec 22, 2005 10:46 AM
webguy330i
Aug 23, 2005 07:55 AM
