Is the problem a bad clutch?
Old Mar 16, 2017 | 03:36 PM
SyHS's Avatar
Hey EvoM. On my way home from the gym this morning I was sitting in my car warming it up. I had the clutch in for about 3 seconds in first as I was getting ready to take off. I noticed that the car started moving forward/bogging in 1st even though the clutch was depressed all the way in. I pulled it out of gear easily and the car was fine. When I do push the clutch in RPM's stay the same(some people with crank I guess get a significant drop in RPMs?). Car is a 06 evo ix built 2.0 from English Racing with a 6466/e85 mini battery. Clutch is an Exedy triple disc. Stock trans and xfer case. This happens every now and then but I just cant figure out what the problem is... Sensor of some sort? I did replace my slave cylinder line with a stainless steel one. Maybe I didn't bleed it completely? There's also a nob/clutch controller under my pedal, is it just adjusted wrong? I did make it home without a problem. My third gear does have a nasty grind to it, could my trans be going bad? Throw out bearing?
Looking forward to responses and I'll keep everyone posted on what I find out.
Old Mar 16, 2017 | 04:08 PM
josh_evo9's Avatar
I would bleed the clutch system again to be 100% sure there is no air. May just need a slight clutch adjustment, the writeup is online
Old Mar 16, 2017 | 04:10 PM
josh_evo9's Avatar
Also, do a thorough visual inspection of every component in the clutch system. My clutch pedal mounting bracket was broken and was causing intermittent gear lockout. Sometimes it shifted perfect, other times I couldn't shift over 5000rpm. Just check over everything and make sure nothing stupid happened.
Old Mar 16, 2017 | 07:25 PM
CeliOnce's Avatar
^ Hmm, how did you determine there was a problem with the bracket? Just clearly broken or did it move a certain way?
Old Mar 17, 2017 | 07:40 PM
barneyb's Avatar
Well, the clutch was obviously dragging a bit. With all the parts that are in a triple this doesn''t surprise me - lots of things to warp a little.
Old Mar 20, 2017 | 08:19 PM
HawkinCrazy's Avatar
I would 2nd this. i had issues when I did a clutch job and didnt bleed the HRB of my 8leg
Ferraritech
24
Apr 4, 2014 12:03 PM
cybertrax
Aug 28, 2009 12:47 PM
jaxjoker
Northwest Region
Jul 17, 2003 12:55 PM
