is this a boost leak
Old Apr 19, 2017 | 06:59 AM
Dmx3alo's Avatar
hey guys, so today when i went around 50% throttle and once the boost passes 0.8 bar (11.6 psi) i can still hear the spool and the boost reading in the gauge rises but the engine goes quiet and the car stops pulling.
please help, thanks in advance
Old Apr 19, 2017 | 11:38 AM
supak1111's Avatar
doesn't sound like it. were you full throttle?
could be ecu retarding your timing for many different reasons
Old Apr 26, 2017 | 02:48 AM
Dmx3alo's Avatar
im stuck between the cas and the leads, that might be causing the problem, any idea how i can identify which one it is
Old Apr 26, 2017 | 11:07 AM
LetsGetThisDone's Avatar
Did you do a boost leak test? I heard those are the best for identifying boost leaks.
Old Apr 26, 2017 | 03:54 PM
supak1111's Avatar
I agree, make you self a little boost leak tester gadget so you can test you full system for boost leaks. IMO anyone with any boosted car should have one of these and do the test every so ofter.
I made one out of a can of beans and a tire valve stem but here is another good cheap way to make it: how-boost-leak-tester for $5
Blacksheepdj
Lancer Troubleshooting
Mar 31, 2005 08:44 AM
Massevo8
Feb 18, 2005 12:55 PM
Tracer
Apr 4, 2004 01:11 PM
