My first engine warning light :-/
Old May 28, 2017 | 05:41 PM
Jonno99's Avatar
Hi guys, well my ix has run flawlessly since I bought it 2years ago, it has a Ecutek programed ECU so I have never played with it, minor mods only. On theweekend I had my first engine warning light. When I started it in the morning Inoticed the idle revs were up around 1200rpm and when I took it out for a runthe engine light came on orange and stayed on.
Ok, I don’t have a OBD2 scanner so is there something I cando visually to check to try and find the fault before I take it to someone??
Also I have a track day in 2 weeks, is the carsafe to drive around, it runs fine and except for the high idle
thanks for any help
Old May 28, 2017 | 06:09 PM
o3evo8's Avatar
Veteran: Air Force
If you don't have a scanner stop by AutoZone or a auto parts store that will check it for you. See what it is before you head out to the track
Old May 28, 2017 | 07:09 PM
kaj's Avatar
kaj
+1 for the autoparts store. You have to get it scanned.
I miss my Honda days, where we could just jump a plug and count the number of flashes LOL.
Old May 28, 2017 | 09:29 PM
barneyb's Avatar
I you own an Evo you should at least have a cheap code scanner. I bought one for 15 bux.
Old May 28, 2017 | 09:45 PM
Jonno99's Avatar
yes agree but they are not cheap here, 140 bucks for a bosch one or 70 bucks for a blue tooth one and an app on your iphone
Old May 28, 2017 | 11:23 PM
RazorLab's Avatar
You can still do that. Evo 8/9/10
Old May 29, 2017 | 02:09 AM
kaj's Avatar
kaj
Then someone needs to hook this dude up.
Old May 29, 2017 | 09:54 PM
Jonno99's Avatar
i just ordered a mini OBD2 blue tooth device for 20 bucks, I'll use the Torque app on my android, hopefully this will work
Old May 30, 2017 | 01:04 PM
barneyb's Avatar
What, not using the flash method? I was waiting to hear how many flashes indicates a "P".
Old May 30, 2017 | 01:11 PM
4G63_EVO's Avatar
I used this except with a 6 dollar bluetooth dongle. Works like a charm. My torque app even picked up a permanent code that ym 200 dollar bosch didnt pick up!
Old May 30, 2017 | 03:46 PM
Jonno99's Avatar
flashing lights are so last decade brother :P
hearnoevo
Oct 14, 2016 09:15 PM
smoke4
Oct 19, 2008 10:18 AM
honda-guy
Jan 13, 2006 04:47 AM
Az3ar
Jun 16, 2004 11:05 PM
