Oil Temp Gauge
Oil Temp Gauge
Both of my fittings near the filter housing are taken (Oil Pressure & Oil feed line.) However, since I converted my oil feed line, the old spot in the head just has a plug.
My question is, has anyone ever used this spot for a Oil Temp unit from AEM? Will there be any interference issues with the sensor sticking into the head or perhaps heat issues from the manifold?
Second question, whats the best way to install a water temp gauge? Is there any stock location where you get get a sensor in the loops? Or do you need an STM water neck
http://www.streettunedmotorsports.co...emp_sensor.htm
Or one of those universal in-line rad hose units?
Interesting question; is it more important to know the temperature of the oil in the pan or the oil being fed into the engine. On cars without an oil cooler the pan temperature is the engine feed temperature but on cars equipped with an oil cooler it isn't.
The oil in the pan is the fluid coming out of the engine. Measuring oil temp in places like the oil filter housing could give false high readings due to the oil having just come out of the pump, or it could be low because it just came back from the cooler and is now going into the engine. Just like with automatic transmissions, the correct place to measure temp is in the pan because that is where all the freshly heated fluid is (kind of like how you measure water temp right before the thermostat). Similarly, in dry sump systems, oil temp is taken from the oil tank/reservoir.
Ant1
18
Jun 1, 2008 09:35 AM
nemosEVO
Mar 27, 2008 01:07 AM
edison
Sep 24, 2006 09:54 AM
