Evo 8 3k rpm wheeze?
Old Oct 16, 2017 | 06:01 PM
DeeEvo's Avatar
So recently I have notice my car is making a different noise....When doing a pull at or near full throttle my turbo begins to spool and you can hear is sucking in additional air, then at 3000-3200 rpm is sounds like its wheezing?
I thought maybe it was a boost leak, but I redid all the couplers.... any else have this sort of problem? vacuum leak maybe? it does not make this noise in neutral, only while driving...
stock block
stock turbo
stock intake
stock intercooler
56xxx miles
Old Oct 16, 2017 | 06:45 PM
BluEVOIX's Avatar
Did you check the turbo for shaft play ?
Old Oct 16, 2017 | 07:10 PM
DeeEvo's Avatar
I will be checking tomorrow evening.
Old Oct 17, 2017 | 03:59 PM
DeeEvo's Avatar
Turbo has no shaft play... I'm stumped!
Old Oct 17, 2017 | 07:51 PM
barneyb's Avatar
Log the knock count while this is occurring.
Old Oct 19, 2017 | 04:35 PM
DeeEvo's Avatar
Here is a quick video I made of the issue.. I think?
IMO you can clearly here the spool start around 3k .. and upon entering 4k rpm is sounds like it is wheezing?
Should the shaft have any play at all? or just be solid. when I move it with some force it moves just a very little bit...
When i spin it with my hand it does not hit the compressor housing.
File Type: mov
Old Oct 19, 2017 | 04:47 PM
Evo__Lee's Avatar
Check the BOV
Old Oct 19, 2017 | 07:29 PM
barneyb's Avatar
Pull enough timing out of a turbo charged car and it will bleat like a goat. That's not what I hear here. It sounds like a simple air leak.
Old Oct 19, 2017 | 07:43 PM
DeeEvo's Avatar
Thanks for the input everyone, I will get some extra time this weekend to dive in. Will report back.
Old Oct 19, 2017 | 08:48 PM
BluEVOIX's Avatar
A tiny bit up/down movement is normal play. Have you also checked for in-out movement ?
Old Oct 21, 2017 | 09:28 AM
DeeEvo's Avatar
BOV looks fine, found 1 stripped Exhaust manifold bolt... Number 2 on the bottom row. Hope that fixes the issues once repaired.
Old Oct 21, 2017 | 12:04 PM
4b11slayer's Avatar
Boost leak test.
Randal
Nov 27, 2012 06:22 AM
211Ratsbud
Nov 11, 2012 01:22 PM
SzuChenEvo
Apr 1, 2003 02:40 PM
