Coolant reservoir cap leak
Old Nov 15, 2017 | 08:24 AM
CaptainSquirts's Avatar
Is it normal for the coolant reservoir cap to leak? I bought a new coolant reservoir and still leaks. Or could something else be causing this? There's no contamination in the coolant in there or anything, I just get an annoying coolant smell.
Old Nov 15, 2017 | 09:33 AM
LetsGetThisDone's Avatar
Did the new reservoir come with a new cap? That really weird. My car has overflowed but only come out the overflow tube, never out of the cap.
Old Nov 15, 2017 | 09:35 AM
It's a new cap.
Old Nov 15, 2017 | 09:47 AM
Biggiesacks's Avatar
might wanna test that coolant for combustion residue. Im thinking you might be blowing bubbles up in that thing.
Old Nov 15, 2017 | 09:49 AM
The coolant should come out the overflow tube, not the cap though. On first session at a track day, my car fills the reservoir and over flows it a bit because the coolant grows so much with heat soak. Doesn't leak from the cap though.
Old Nov 15, 2017 | 09:51 AM
thats kinda why i was thinking bubbles, only way i could see coolant kinda spraying / pressure spiking inside the overflow.
Edit: by contamination do you mean you already checked for combustion residue?
Old Nov 15, 2017 | 09:54 AM
How would I go about doing this?
Old Nov 15, 2017 | 09:56 AM
they sell little tester kits at most auto parts stores, or just Amazon.
Old Nov 15, 2017 | 10:14 AM
Valid point.
You're looking for a block tester. this
Amazon Amazon
and you'll also need the fluid, which is on that page, available to buy as a package.
Old Nov 15, 2017 | 10:39 AM
Purchased, I'll post results probably on friday whenever I get it. Thanks
Old Nov 15, 2017 | 11:17 AM
RightSaid fred's Avatar
They don't work.
Just check for bubbles coming out when you blip the throttle.
Old Nov 15, 2017 | 12:44 PM
heel2toe's Avatar
Make sure the cap is fully seated and the rubber gasket is still intact and not pinched. I know myself personally there have been times where mine didnt seat properly, really just user error on my part. Now out of habit when I put back on the cap I sorta twist it side to side to make sure its fully seated. Seems silly but might be as simple as that. Or perhaps the gasket is gone?
I wouldnt start thinking the worst already; might be something totally stupid like that.
Old Nov 15, 2017 | 05:09 PM
barneyb's Avatar
Black light with dye photograph - interesting.
Old Nov 17, 2017 | 03:31 PM
Did the combustion leak test, and results are clean. So I'm guessing just the seal on the coolant cap is bad then?
Old Nov 17, 2017 | 05:58 PM
barneyb's Avatar
To answer your original question, no, its not normal for the cap to leak. On a cold engine, with the reservoir level topped off to the full mark, in normal driving the coolant level never climbs to the level of the cap.
