Radiator fan control
Old Jun 5, 2018 | 09:02 AM
nor11384's Avatar
FCOTM Winner
Hey guys I’m having an issue getting the stock radiator fan to turn on at a lower temp. I used to have a mishimoto fan and I set it to turn on at like 190f - 195f on ecuflash and it worked but when I switched back to stock fan it won’t do it. It will turn on 203f - 206f. Does it not work with stock fan or is there something special that needs to be done?
Old Jun 5, 2018 | 11:50 AM
LetsGetThisDone's Avatar
As long as it it's wired into the factory fan controller, it should respond accordingly to inputs in the fan duty table.
Old Jun 5, 2018 | 12:58 PM
nor11384's Avatar
FCOTM Winner
It’s wired into the fan controller like factory...
Old Jun 10, 2018 | 02:43 PM
nor11384's Avatar
FCOTM Winner
still having issues with this...fan wont respond...just turns on like factory...
Old Jun 11, 2018 | 04:19 PM
barneyb's Avatar
The factory fan works pretty good, what's the problem?
Old Jun 11, 2018 | 05:30 PM
nor11384's Avatar
FCOTM Winner
I’m trying to get it to start at 195 f but it won’t. It will turn on at like 203 f. I went to the below 20 kpa table and set it to 70 at 195 f and won’t start.
Old Jun 15, 2018 | 08:54 PM
nor11384's Avatar
FCOTM Winner
Any ideas? I cant get the thing to start at 195 f. It wont will just start at 203f. I noticed in periphery 1 theres an option that says "2nd thermo fan table". Anyone have any idea what thats for?
Old Aug 7, 2018 | 09:12 PM
Raceghost's Avatar
Yes, turn that on.
Can anyone point me to the orignal fan tables found by MFRED, back in the day. I need to reread some info in that thread he originally posted with source code for ECUFLASH. Sorry, not trying to hijack.
Old Aug 9, 2018 | 12:05 PM
TrendSetter's Avatar
which rom?
here is 8859
<table name="Thermo Fan Duty 0-12mph" category="Miscellaneous" address="5186" type="3D" level="2" swapxy="true" scaling="Percent (128)">
<table name="Conditions" type="Static X Axis" elements="3">
<data>Main Fan 0-12mph</data>
<data>A/C Fan 0-12mph</data>
<data>Main+A/C 0-12mph</data>
</table>
<table name="Engine Temp" address="7034" type="Y Axis" elements="12" scaling="Temp"/>
</table>
<table name="Thermo Fan Duty >12mph" category="Miscellaneous" address="4012" type="3D" level="2" swapxy="true" scaling="Percent (128)">
<table name="Conditions" type="Static X Axis" elements="9">
<data>Main Fan 12-31mph</data>
<data>Main Fan 31-50mph</data>
<data>Main Fan 50->>mph</data>
<data>A/C Fan 12-31mph</data>
<data>A/C Fan 31-50mph</data>
<data>A/C Fan 50->>mph</data>
<data>Main+A/C 12-31mph</data>
<data>Main+A/C 31-50mph</data>
<data>Main+A/C 50->>mph</data>
</table>
</table>
DJ Brett B
Jul 12, 2009 06:14 AM
gsrboi80
Feb 20, 2009 08:04 AM
PHILLY EVO
Apr 17, 2008 10:48 AM
