Starter trigger wiire
Old Jul 4, 2018 | 01:52 PM
benIX's Avatar
hello everyone happy 4th,
i have a question. I’ve been having some issues with my starter when it gets hot outside my starter will click once every time I try to turn the car on. So I have to keep trying to turn the car on and after 10-15 clicks it finally turns on. I red somewhere that the issue is the trigger wire. Does anybody know where the trigger wire is? Or know where to look?
thinga I’ve done so far
changed the ignition switch
changed starter selenoid
disabled alarm
disabled turbo timmer
and it still does it battery is brand new and whn the car is on I have no problems at all. Sorry if I’m bringing this back from the dead I just don’t know what to do at this point so I like to get some experience help. Thanks in advance.
Old Jul 5, 2018 | 08:31 AM
FRESH.I.AM's Avatar
I have the same issues as you and also done the exact same things you did. I hope someone chimes in on the fix to this.
Old Jul 5, 2018 | 01:33 PM
barneyb's Avatar
There's two wires connected to the starter. One is a thick wire coming directly from the battery. The other is the signal (trigger) coming from the ignition switch.
Old Jul 5, 2018 | 08:17 PM
JohnnyTSi's Avatar
Read through this entire thread, my car had the exact symptoms and the Ted B designed solenoid rewire fixed mine permanently.
https://evolutionm.net/forums/evo-ge...-fixed-13.html
Check out post 148 for details.
John-
ru4real
Jun 27, 2016 10:14 AM
nor11384
Feb 20, 2016 05:06 PM
bmann_420
Lancer Troubleshooting
Feb 3, 2015 03:11 PM
Blue91lx
May 9, 2012 11:15 AM
Routybouty
Nov 25, 2010 04:13 AM
