Evo 8 5 speed to 6 speed mr swap help parts
Old Jul 19, 2018 | 08:28 AM
Evo8yu's Avatar
Hey i did search the forums but mostly all the info is the swap from 6 speed to 5 speed.
I am trying to make sure i have all the parts for the swap from 5 speed to mr 6 speed
so far what i know is i need the
- 6 speed tranny
- 6 speed shifter and cables
- transmission harness for 6 speed
- harness for reverse switch 6 speed
- reverse switch or solenoid? For 6 speed
- 6 speed tranny mount
- lower clutch line
- cable bracket (trans side)
Am i missing anything? Or does anyone have exact part list for the swap? Thanks
Old Jul 19, 2018 | 09:35 AM
LetsGetThisDone's Avatar
You're missing the fact that you're installing a weaker transmission in your car...
Old Jul 19, 2018 | 11:27 AM
kaj's Avatar
kaj
It's all the same parts you swap out for the 5spd. I don't remember needing to change the harness for the reverse switch, specifically. just the trans harness itself. You can tweak the hardline for the slave cylinder, so don't need to change it, though you may need the bracket that the hard/soft line union attaches to...? It's been a while. I'd have to go back and look LOL. Other than that, I think your list is accurate. When I bought my 6spd, I got a bunch of extra stuff. I can take a look at what I have, if you need any. I think I have the cables, shifter, trans bracket.. maybe some other stuff.
Old Jul 24, 2018 | 06:31 AM
Rolston12's Avatar
i swapped to a 5 speed 2 years ago i have all the parts for a 6 speed if needed, you will also have change your speedo sensor 6 speed is magnetic and the 5 speed is mechanical.
Old Aug 3, 2018 | 08:45 AM
detroit evo's Avatar
Evo8yu
Not sure what you are trying to achieve with the swap.
I had this same goal for a short time. For me I was thinking that with my 1 hour commute on 70mph speed limit highway that I might save some mpg. Why would I research such a thing? I realized that at above 65mph speeds I am generating enough boost with the base map and stock powertrain that my mpg would be greatly impacted. So I commute at about 65mph most times which feels like a death wish in Michigan so often I am up at 70 to avoid road ragers. After doing the math on the ratios I came to realize that I would only drop about 200rpm at the same speed with the 6 speed trans.
Given my research notes it reads that you should have all that you need.
Old Aug 3, 2018 | 01:27 PM
kaj's Avatar
kaj
MPG is not a good reason to want a 6spd trans, I agree. I have mine for other reasons that are more important than MPG, but that's just me.
Evo8yu
Jun 22, 2019 10:34 PM
Tanman1986
23
Jul 25, 2010 12:17 PM
AMSTuning.com
Mid-Atlantic Region
11
Oct 11, 2006 06:29 AM
