06 evo battery drain help
My stepson is deployed and we had his 2006 evo with 58,000 shipped home. After the car sits for a couple days the battery is toast. the wipers, radio and clock still have power to them and will operate like normal with the key out. There is an aftermarket alarm and radio, he replaced the battery last month and I just charged it and added a battery shut off, voltage is 12.7v and 13.9v when the car is running. I was thinking it could be the ignition switch? I’ve already checked the wiring on the left driver kick panel and it didn’t appear that any water is getting and and there’s no corrosion. Any help would be appreciated. Thanks
Hi Bryce. Well could be a couple of issues
Joe
- First check if the alternator is properly working
- If the Alt is OK, it is likely just a battery issue (after all it has been sitting). Possible drain issue w/this alarm system
- Battery should be trickle charged during his deployment which will keep the charge level proper
Joe
Joe
Joe
Carefully go through all the wiring for the alarm and radio, that's likely where you'll find the issue.
Well here is the problem. Lol ****ty radio install.
they had red (ignition) yellow (accessory ) and orange (illumination ) were all connected together. With the harness plugged in the wiper have power the radio and clock without the key in the ignition which I’m figuring was drawing the battery down. There is a factory amp, I know how the yellow and red wire hooks up, does anyone know if the blue wire from the factory side and the blue wire from the radios side and the blue wire from the amp plug all connect together? Also does the illumination wire go to the ignition wire (red) it’s a kenwood. Thanks for all the help
With aftermarket units, yellow is your battery 12v, red is your accessory (hot when key is on I), blue is remote signal to turn on amp, orange dims the CD player when light is on.
