EVO 8, aftermarket oil cooper help.
Old Apr 22, 2019 | 11:35 AM
Biro's Avatar
EVO 8, aftermarket oil cooler help.
Hey!
I’ve bought an aftermarket oil cooler with filter relocation as well. I’m currently about to get it installed but I’m a little bit confused.
This is the kit I bought:
https://www.amazon.com/gp/product/B00ZVMQQMI?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00 https://www.amazon.com/gp/product/B00ZVMQQMI?psc=1&redirect=true&ref_=oh_aui_detailpage_o02_s00
The thing is, that I guess i have to buy some separate couplings for the AN pipes to get it attatched to the oil filter housing or am I wrong? Since I can’t figure out any other way. If so, what kind of adapter/couplings do I need?
The old OEM cooler had banjo bolts. But I can’t reuse em since the new system got AN couplings.
I guess it’s like M12 - AN10 (m12 is just an example it might be too small tho)
I’ll attach some pictures.
and if someone is willing to, I would appreciate any write up guide how to install it the correct way since I didn’t get any documents at all with the cooler.
Kind regards, Biro
Old Apr 22, 2019 | 12:15 PM
Biro's Avatar
I did some google searches and managed to find some valuable information now.
i guess what I need is 2x m18 - AN10 adapter. Anyone can confirm?
Old Apr 22, 2019 | 02:08 PM
heel2toe's Avatar
Dont use that sandwich oil filter plate as our OFH already has provisions for the oil cooler lines. What you need is adapters, I think they are an m14x1.5 to -10AN but Im not positive as that is from memory. Youll need crush washers too for the adapter on the OFH side.
This is a really nice oil cooler kit: https://www.maperformance.com/produc...n-8-9-evo-ock#
Take a look at the fittings on the left side of the picture as those are the adapters im referring to.
Old Apr 22, 2019 | 02:38 PM
Biro's Avatar
Oh, alright! Then i skip the sandwich plate, and keep my filter at the regular OFH spot.
And i order a pair of (?)M14x1.5 to -10AN and some crush washers.
One more question, may you know the size of the two ports for oil temp/pressure on the OFH?
I would need to order adapters for those as well, (someting - 1/8" NPT for the sensors)
Old Apr 22, 2019 | 02:57 PM
heel2toe's Avatar
Please confirm the M14x1.5, Im sure the info is on here somewhere. You could also just confirm with your old lines and a bolt and or nut to be positive. As for the ports on the OFH for the oil temp/ pressure those are 3/8 BSPT. Not NPT but BSPT.
If you have to crack those plugs loose be sure to preheat with a torch to break up the red loctite and then they will come right off.
Old Apr 30, 2019 | 12:36 AM
Biro's Avatar
Can i have the inlet at bottom and return at the top?
Even tho the OEM cooler have feed from top and return at the bottom?
Old Apr 30, 2019 | 09:00 PM
LetsGetThisDone's Avatar
You need to return that kit and and leave the stock cooler on the car. I'll put money on it that the OEM cooler works better than a $140 kit made in who the **** knows where.
Old May 1, 2019 | 12:28 PM
Biro's Avatar
Well, I’ve already bought it (260USD) here in Sweden, and already mounted it as well. So I hope it works anyway And I can reuse the OEM cooler since I had a spun bearing and the guy at the shop told me it’s pretty much impossible to flush it all out of the cooler.
Old May 1, 2019 | 12:55 PM
That guy is right, can't reuse the stock one.
