Coolant Leak/Transfer Case question
Old Oct 28, 2019 | 01:13 PM
buzzskyline's Avatar
Coolant doesn't run through the transfer case housing, does it? I ask because there is a coolant leak that appears to come from the connection between the transfer case and the transmission on my Evo 8.
I'm guessing something is leaking on top of the transfer case and it's running along the joint to make it appear to be leaking between the transfer case and tranny. Bu I want to make sure that I don't have to worry about it being a gasket between the two.
Old Oct 28, 2019 | 02:10 PM
heel2toe's Avatar
Correct, no coolant runs through the xcase and tranny. Id check the water lines running to your turbo as I've had a similar leak that stemmed from those and noticed coolant sitting on my trans bell housing.
Old Oct 28, 2019 | 02:14 PM
Pal215's Avatar
Right. That leak is either coming from your throttle body lines or turbo coolant lines. There are also the heater core lines that could leak over your trans if the hole is in the right place.
Old Oct 28, 2019 | 02:16 PM
heel2toe's Avatar
Right yeah good point those TB lines go right to the head as well so good idea to check those as well!
Old Oct 28, 2019 | 03:49 PM
Right you are! It's the hose to the throttle body. Should be a quick fix as soon as I can pick up some hose.
Thanks to all of you who got it right. What great forum this is!
Old Nov 1, 2019 | 09:30 AM
TEXAS_SPEC's Avatar
check the housing in cylinder head. mine was leaking and ran down the tranny area
mrischer
Apr 24, 2015 11:56 AM
nor11384
Jul 3, 2014 02:59 PM
evol evo
Oct 23, 2011 06:26 PM
Tsurara
21
Jul 2, 2011 11:37 AM
cweav
49
Jul 8, 2009 04:36 PM
