Evo IX bogs down under load
Old Oct 29, 2019 | 01:14 PM
thedru13's Avatar
random issue. The car was sitting for a while and gas tank was low. I put some gas in the car and took the car out and after it was warmed up I boosted the car and it spooled up and then all of the sudden bogged down and felt like it was going to stall. So I thought maybe something on the fuel pump filter got stuck. I pulled the fuel pump and replaced it as well as a new filter. Buttoned everything back up and the same issue. I thought maybe a boost leak .. Did a boost leak test no leaks. My only other thought is a clogged injector/s . anyone else has any thoughts.
Old Oct 29, 2019 | 01:51 PM
miragevo's Avatar
Veteran: Navy
bad plug
Old Oct 29, 2019 | 02:05 PM
thedru13's Avatar
I checked the plugs and they looked okay. I will swap them out and see if that helps.
Originally Posted by miragevo
bad plug
Old Oct 30, 2019 | 02:06 PM
IEXCELR8's Avatar
Stock cat or high flow?? Any weird smell? Does it boost at all??
Old Oct 30, 2019 | 03:27 PM
thedru13's Avatar
Catless. No smell no abnormal color smoke out the muffler. As soon as I get on the gas it bogs right out and SES will flash. I should probably scan it to see if I am getting any codes.
TariqEvo
12
Oct 23, 2017 10:31 PM
Driv200
Oct 20, 2017 09:47 PM
michaelanjolo
Sep 16, 2015 09:27 AM
ddfelix5494
Feb 20, 2009 12:09 PM
akauf
27
Oct 11, 2008 02:56 PM
