Electrical Help: Headlights
Old Nov 13, 2020 | 09:30 PM
Dm30213's Avatar
So I’ve just finished installing everything back into my project evo 8 (engine, trans, engine harness etc.). But now I’m having some electrical issues with the headlights. Driver side, the main lights turns on but not the high beam. Passenger side the high beam turns on but not the regular lights. Ballast on both sides in working order because if I plug passenger headlight into driver side it works. I’m thinking it’s a grounding issue but trying to see if anyone may have a better idea than I?
Old Nov 14, 2020 | 06:54 AM
Jp7's Avatar
Jp7
If you have a grounding issue measure the voltage on what should be your ground WHEN the circuit is turned on and loaded. If you have a bad ground, you will see a high number (like 12 or 14v)
Old Nov 14, 2020 | 07:11 AM
Dm30213's Avatar
Thanks will try this
Old Nov 27, 2020 | 03:42 AM
Royal Evo's Avatar
Could it be the headlight switch assembly that is bad?
GordonVIII
Feb 2, 2017 12:00 PM
Peanut1234
Northwest Region
18
Aug 22, 2011 10:52 AM
arnold16890
Aug 6, 2007 03:09 PM
mitsubishimanny
04-06 Lancer Ralliart How To Requests / Questions / Tips
Nov 5, 2004 10:31 AM
