How can i readjust the headlights
Old Oct 20, 2004 | 03:15 AM
mitsubishimanny's Avatar
is there a way to readjust the headlights. the manual says to take it to a mitsubishi mech to do it. is there a way to do it without takin it in?.
Old Oct 22, 2004 | 12:11 AM
IllicitRalliart's Avatar
Not really considering the equipment used to aligne/adjust the Headlights properly is far more expensive than anyone wants to pay to readjust the lights properly every great now and then.. If the lights are off center and you havent touched them then it should be covered under your warranty.If you did something to them or took them out and put them back in,then you will be paying for it.When it comes to properly aligning your headlights.. I would suggest you take it to the dealership.Let them deal with it.I have done a few headlight adjustments and they take a little bit of time and are generally a PITA..
Old Oct 22, 2004 | 12:15 AM
ghostrider's Avatar
You can adjust the headlights by using the two sets of screws around the headlight housing. One moves it vertically while the other moves it horizontally. All you gotta do is get your car on level ground at night and flip your lights on. The hardest thing will prolly be to find the screws in the first place.
Old Oct 22, 2004 | 05:11 AM
yeah
yeah i cant seem to find them. anyone have any idea where they might be???
Old Oct 22, 2004 | 08:55 PM
Red Dragon's Avatar
i cant find them either.... pretty tricky those things are... hinding on me..
Old Oct 23, 2004 | 01:31 AM
YEah it generally is screws.. But to get the headlight aligned without a headligh alignment machine is a pita.. Unless you want to drw a perfectly straight and even line and park your car close to it and then adjust it that way...And you have to know beyond a shadow of a doubt that the ground is level.Like I said I have done a few headlight adjustments and they are a PITA.. once you adjust one the other Goes out of line.. If you really want to do it yourself.. you make 2 marks like this + where the center of the headlight is supposed to be.The marks must be perfectly Even and perfectly spaced,then park your car up clost to the wall you drew those on and adjust them from there.. The light from the lamps should be perfectly in the center of marks( right where the vertical crosses with the horizontal line).. Like I said,It is a headache to do and I would personally leave it to the dealership.Just my opinion.
Old Oct 23, 2004 | 12:06 PM
turbonutter's Avatar
Agreed... I've never gotten 'em done right on my car, it's got a lazy eye lol.
Edit: My OLD car
Old Nov 5, 2004 | 10:31 AM
importstylz07's Avatar
how much would mitsu charge to align em?
4G63_Crazy
May 6, 2017 09:06 AM
2rbolag
Nov 18, 2016 03:24 PM
roni4g63
Mar 29, 2016 09:26 AM
stefenboy
Dec 9, 2015 03:20 PM
def1
Aug 2, 2009 07:51 PM
