EVO 9 cranking but not starting
Old Nov 25, 2020 | 05:46 AM
Stockafevo9's Avatar
Whats up guys currently having some trouble with my evo
I have it in a garage stored for like 4 month with battery pulled. Last week i install my new straight pipe and down pipe. I went ahead and tried to start it and it was just cranking but not starting. It was running prior to storing for such a long time.
I tried to troubleshoot last week but fell short because I left my multimeter at a job site.
TomorroW since I have Thanksgiving off from work I will be back at it.
Here what I know:
I am getting fuel pressure (since I have my multimeter now i will check to make sure I'm fuel injectors are getting signal to fire.)
I checked for spark and none of my spark plugs are getting spark (i figured this is weird because typically not all go bad, tomorrow I will test coil packs)
Relays and fuses, I decided to check all ignition fuses and fuel fuses all seem to look good. (I will check my relays tomorrow)
Now I know my Crank position sensor can cause my fuel injectors not to fire and my spark to go bye bye. But this will be my final check.
Anything else I should look for that I haven't covered?
Also no CEL codes
Thanks for the help and knowledge.
Old Nov 26, 2020 | 10:35 AM
You can close this thread found my ecu burned up.
Kris86
May 22, 2017 10:53 PM
moyassine
Feb 21, 2016 10:54 AM
fullm00nevo
Jul 31, 2015 10:47 PM
scheides
May 28, 2015 12:01 PM
Mertins03
Apr 29, 2009 03:39 AM
