found in bell housing of transmission
Old Apr 30, 2021 | 10:41 AM
phantastic's Avatar
had a bolt come undone from the starter plate and was flopping around inside the bell housing of the transmission. along with this bolt i also found other metal debris when i removed the flywheel/inspection cover and thought was the clutch retaining collar, but tis not. upon removal of the transmission everything seems in tacts: TOB, fork, flywheel has no damage, clutch disc has some damage from that bolt flopping around in there but nothing resembles the metal pieces. same with pressure plate, only visible damage are small scratches and cant find anything that resembles these pieces, and retaining clip is also in one piece no damage.
would appreciate identifying what the frekk this is, much thanks
Old Apr 30, 2021 | 02:40 PM
Yeah, thats is an issue for sure. Looks like a splined shaft washer / spacer. Further investigation is certainly needed!
I know im pointed out the obvious but it shouldnt be that difficult to ID that washer
Old Apr 30, 2021 | 04:19 PM
hutch959's Avatar
i have no idea
BrianBarnes
13
May 16, 2017 11:51 AM
jacked cobra
Jan 28, 2015 02:22 PM
SSP-Ralliart
Jul 22, 2011 05:07 PM
italianevo88
Jun 25, 2011 11:49 AM
agolgan
Jul 6, 2008 05:47 PM
