Loud rubbing noise
Old May 12, 2021 | 09:36 PM
rage mang's Avatar
Loud rubbing noise
Hello
Can anyone help have a loud rubbing noise coming from the right rear whenever i need to go right up ramp initially thought it was tire rub but no evidence of rub on fender or tire any help would be appreciated.
Noise only happens when turning right up an incline and rubbing sound comes from the right rear side.
Specs.
Evo 6 on d2 coilovers
Standard oz wheels and stock tire 225.
Energy suspension poly bushes.
No other suspension or mechanical mods on transmission/differential.
Old May 13, 2021 | 04:31 PM
hutch959's Avatar
gotta be the tire/wheel/ brake... hitting something
Old May 13, 2021 | 06:53 PM
Make sure the dust shield is not rubbing the rotor. Easy to bend a dust shield mounting wheels or other wheel end work
Just thinking
Old May 19, 2021 | 05:44 PM
Grevolution's Avatar
Just thinking
I second all the above suggestions. Also rust build up on the dust shield causing the rotor to touch the shield are the Evo 6 rear brakes similar to the Evo 8 setup? Does it do it when it is cold or when it is hot? That can be a telling sign if it is brake related. The other possibility is the hub bearing. You can check the hub for excessive play with the wheel on.
Betty
Apr 30, 2012 12:59 PM
Hanzo
Feb 13, 2008 11:00 PM
dsm25psi
Aug 6, 2007 06:55 PM
MuslimEvoFreak
Sep 9, 2006 02:48 PM
ralliart86
Sep 24, 2004 09:01 PM
