ACD Malfunction: Code 74
Old Jun 10, 2021 | 04:55 PM
Turtletron's Avatar
5 Year Member
I was at the track last month in hot weather and on the second day my ACD lights all went on. After restarting the car for the next session they were normal again but only for a few minutes.
Eventually they got to the point of the lights always being on and giving me a code 74 when I check them, which is supposed to be for the proportional valve and wiring.
Originally the car would prime the pump with the key turned and throttle pressed but now it doesn't even attempt it and the relay doesn't click, does the ACD computer not prime the pump if there is an existing error? I unplugged the battery for a while but it didn't help.
Pump and proportioning valve solenoid both work fine with 12v applied. The internals of the pump are pristine, I bought this unit used a couple of years ago but it must have been a factory replacement or something. I checked the pump wiring and it was good, as well as the relay and fuses.
At this point the only possibilities I can come up with is the computer itself malfunctioning or the proportioning valve itself somehow even though it opens fine. Has anyone experienced a code 74? Any ideas of what might be going on?
And for the record driving on track with an open center differential is a pain.
Old Jun 11, 2021 | 09:53 AM
CDrinkH2O's Avatar
It sounds like it could be an intermittent short or open circuit in the proportioning valve solenoid circuit that only happens on track. Double check each section of the wiring from ECU > Passenger footwell connector > Front harness > solenoid plug for continuity and resistance. Check the solenoid resistance (coil insulation degrades with heat and age), and then measure the current draw through the solenoid when battery voltage is applied. Here are the FSM troubleshooting pages for reference.
This could be useful if you find the solenoid is the problem.
File Type: pdf
sktng22
Aug 13, 2013 06:14 PM
Ahyesican
Mar 6, 2012 03:46 PM
ahmed moustafa
Feb 24, 2012 11:05 AM
GTijoejoe
Dec 21, 2011 02:05 PM
Jaeger19
Oct 8, 2011 11:16 PM
