Boost leak
Old Aug 21, 2021 | 04:38 PM
TimThatch04RS's Avatar
Boost leak
I did a boost leak test and have found a leak on what seams to be the iacv. Right under the charge pipe coupler. Would this be leaking cause of a bad iac valve or o ring or do you think it's the throttle body shaft seals that are causing it to leak there? Possibly both I guess. Any thoughts?
Old Aug 22, 2021 | 04:26 PM
hutch959's Avatar
if you feel it coming out of the iacv valve... may be the oring...
easy enough to pull it out and check it.
Old Aug 22, 2021 | 05:20 PM
i can’t feel it but when I spray it with soap and water it looks to be around the top of the iavc valve near the screw closest to the throttle cable. I also am running injector dynamic Id1000cc injectors I want to replace the seals as well. Would you know if I can use OEM seals or? Stock fuel rail.
EvODavO
Feb 12, 2009 05:25 PM
aspensvt16
Aug 10, 2008 04:35 PM
yikez
Dec 11, 2007 08:52 AM
joedr
Mar 9, 2006 10:51 AM
