spark plug recomendation
Old Aug 22, 2021 | 04:37 AM
JamieEVO8's Avatar
5 Year Member
my evo 8 is lightly modded(340hp nothing special)
it has a spoolin up cop but dont know what spark plugs the previous owner used and cant get the COP off cause its soo ****in tight on that i have to drill it out
its running 1.2-1.3 bar boost
Old Aug 22, 2021 | 05:08 AM
Stock specification plugs is what most of us use in our 4G63's
Old Aug 22, 2021 | 05:10 AM
JamieEVO8's Avatar
5 Year Member
one says NGK's the other say denso(MD343244 Denso P22PR8)
so which is it?
Old Aug 22, 2021 | 05:47 AM
Well, i know the spec for my EvO 9 = NGK ILFR7H
Not sure what the 8 runs off hand. I'll leave that to you to figure out Sir
There are scores of threads on this same topic
Old Aug 22, 2021 | 11:58 AM
RazorLab's Avatar
Stock heat range:
NGK – BPR7EIX
Denso – IW22
1/2 step colder:
NGK – BR7EIX
1 step colder:
NGK – BPR8EIX
Denso – IW24
1 1/2 step colder:
NGK – BR8EIX
Old Aug 22, 2021 | 04:23 PM
hutch959's Avatar
evo 8... just use the ngk coppers.
Old Aug 22, 2021 | 06:43 PM
RazorLab's Avatar
Yup. Just take off the IX at the end of the plugs in my list above and replace with an S
Example: BPR7EIX = BPR7ES
Old Aug 25, 2021 | 10:46 AM
Kevin.'s Avatar
Stock plugs are 6's I believe.
My tuner said coppers for 8s and iridium for 9s
colder the plug heat range the more power you make.
Old Aug 25, 2021 | 12:07 PM
RazorLab's Avatar
Stock heat range is 7
Old Aug 25, 2021 | 04:27 PM
LetsGetThisDone's Avatar
Stock heat range is 7.
The correct plug makes the most power. Arbitrarily going colder helps nothing. Stock heat range is good to around 7-750whp in these cars.
Old Aug 30, 2021 | 07:00 AM
Kevin.'s Avatar
DSM EVO dyslexia
Old Aug 30, 2021 | 04:21 PM
hutch959's Avatar
i like that!
wonder if they make 0 heat range plugs.
gonna get me some
Old Aug 30, 2021 | 05:37 PM
Jonno99's Avatar
I read a lot on here and also my tuner recommended denso IKH24 for a 100hp up on stock build. Like letsget says it probably doesnt matter going colder at low hp
Old Aug 30, 2021 | 05:50 PM
RazorLab's Avatar
I run stock heat range plugs at 650whp with higher than stock compression and E85, but it's an Evo 10, so not a "real evo".
ultraflip
29
Mar 24, 2017 10:19 AM
bnr34rb26dett
Apr 28, 2013 08:55 PM
apham5
Mar 9, 2013 03:10 PM
Czarcasm
21
Feb 19, 2013 08:31 PM
