Transfer Case drain plug threading
Old Feb 7, 2022 | 09:49 AM
Kevin.'s Avatar
Those quart bottle hand pumps sometimes end up being single-use
Old Feb 7, 2022 | 10:00 AM
kyoo's Avatar
yea i actually started filling from the top with a funnel & hose, but that was a two-person process. This sounds better, just need to figure out which tools are the right ones
Old Feb 7, 2022 | 10:07 AM
ViciousLSD's Avatar
My HF one is still going strong, but I really end up using it as a 2-hand pump (horizontally) so we all fit under the car.
Old Feb 7, 2022 | 10:21 AM
Kevin.'s Avatar
I'm a sloppy 'mechanic'
found this gem:
https://www.jackstransmissions.com/b...t-case-filling
Old Feb 7, 2022 | 10:24 AM
ViciousLSD's Avatar
found this gem:
I thought I read someone say tranny oil comes out of the tail lol
Old Feb 14, 2022 | 06:49 PM
kyoo's Avatar
anyone else found a good piece(s) to attach for this job?
Old Feb 14, 2022 | 08:16 PM
ViciousLSD's Avatar
this?
Amazon Amazon
Old Feb 14, 2022 | 08:18 PM
kyoo's Avatar
precisely what i was looking for, thanks
Old Feb 25, 2022 | 02:33 PM
ViciousLSD's Avatar
this works fine
"quick release"
Old Feb 25, 2022 | 03:49 PM
kyoo's Avatar
what is that? a rubber stopper?
Old Feb 25, 2022 | 04:01 PM
ViciousLSD's Avatar
just a stub of (~12mm?) silicon hose. it can get threaded in. I use the very same one on the filler holes
Old Mar 19, 2022 | 08:39 PM
kyoo's Avatar
ok - i just used this:
Amazon Amazon
with this pump:
Amazon Amazon
worked really, really well. the black tip of the pump actually fits right INTO the hole of the barb and stays there. the hole of the fitting from the first link is kind of on the large side, but just makes getting the fluid in easier, I imagine.
i'm still working on a container solution to put the pump into though. for now what i did was pour it into an open measuring cup essentially, filled it with the quart, and pumped it into the t-case. as others mentioned, I almost got the entire quart in. i'd say the overall amount of fluid lost between disconnecting everything was fairly minimal, and in any case much more fluid in the t-case than from the pump-til-it-drips method, or even my extreme tilt-the-car method.
will continue with this method in the future. i'm hoping this container:
Amazon Amazon
will connect to that new pump i've got and that'll make life easier.
thanks a lot, this worked much better than I thought and frankly not even as messy as I was worried it'd be, probably even cleaner the regular method.
EndlessRed
Evo X How Tos / Installations
10
Aug 14, 2011 03:29 PM
tmartin
Dec 29, 2008 07:47 PM
03SilvaEvo
Jul 16, 2005 05:44 PM
