How to pull milage from unplugged gauge cluster
Old Jun 4, 2022 | 01:36 AM
raverthug's Avatar
While my car is down for a full rebuild I got a different gauge cluster to put in it. Unfortunately I don't know the milage. Is there a way to check the milage without installing it in a car that can power it? This is on an evo 8.
Old Jun 4, 2022 | 07:19 AM
Biggiesacks's Avatar
It looks like You need Switched Ignition on Pin 9, Battery Constant on Pin 7, and ground on Pin 1, 2 of connector C-01. If you aren't familiar with reading these mitsubishi diagrams then there is a section in the beginning of the electrical part of the factory service manual that explains how to read them. I would still verify everything before trying to apply any power to the cluster. Check that the wire colors of the specific position on the connector match what you think they should be. It's easy to get the connector positions backwards and you don't want to reverse power the cluster and fry it.
Old Jun 4, 2022 | 11:54 PM
raverthug's Avatar
Awesome thank you so much
12WWGSR91
Jul 20, 2014 09:21 PM
nutnbutturbo4
Jun 21, 2004 02:01 AM
livelyjay
Feb 2, 2004 10:15 AM
