Evo8 idle control valve
Old Jun 4, 2022 | 07:42 PM
Evo9 FTW's Avatar
So I just bought an 03 Evo8 and the idle was always around 600 rpm, then I replace the new valve that came with the car and the idle gets normal when cold starting, but it doesn't want to go below 1500 rpm and keeps trying to go over 2000 rpm even the car is fully warmed up. My question is that is it a faulty valve or does the idle needs to program somehow? Thanks for any help.
Old Jun 5, 2022 | 11:21 PM
kaj's Avatar
kaj
Can you swap the old one back on?
Old Jun 6, 2022 | 07:03 PM
Evo9 FTW's Avatar
Already did, now it's back on 600 rpm routine, it is better than burning the gas for nothing
Old Jun 7, 2022 | 07:03 AM
XSivPSI's Avatar
Have you tinkered with the BISS screw? Search for info on how to set it properly, could help.
Old Jun 7, 2022 | 08:48 AM
Tomkun's Avatar
what’s the best method to properly adjust the bias screw. I’ve seen where you go into evo scan and disactivate the iscv and adjust the bias screw till it matches the desired rpm. The other methods is to monitor the “iscv demand with ac off” and try to get it to 0v.
Old Jun 7, 2022 | 09:38 AM
kaj's Avatar
kaj
"iscv demand with ac off” is the best and most accurate way but it's not always an option in EvoScan. I haven't been able to figure out why it disappeared from my menu.
Old Jun 7, 2022 | 02:38 PM
Kevin.'s Avatar
I believe 900 is normal for base idle fwiw
Old Jun 12, 2022 | 04:31 AM
WRC-LVR's Avatar
850 rpm
Old Sep 4, 2022 | 07:07 PM
Evo9 FTW's Avatar
Do you mean that I should do it with the old valve on or the new one?
So for the old one, when I cold start it, it would go straight to 600 rpm, I assume a functional one should go around 1500?
For the new one, I am not sure that would help cause the new one has jumping idle not steady.
Alex1743
May 28, 2020 04:32 AM
MrJuls
May 13, 2012 05:13 PM
MrJuls
Apr 16, 2012 10:52 PM
SW20Mike
Aug 24, 2011 05:40 PM
ironmikep
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jan 6, 2011 01:33 PM
