Labor for replacing Mivec Cam Gear
Old Sep 13, 2022 | 10:29 AM
pistons4550's Avatar
Hey guys, looking to see what you all feel sounds about right for labor to replace the mivec cam gear. Mechanic quoted it as labor to remove and replace timing belt, about 540 dollars, but a lot of the threads I’m reading State that the timing belt does not need to be removed to replace the gear. I’m wondering if he’s actually gonna remove it or just used that as a labor estimate.
also, how long do those cam gears typically last? I’m at about 150k miles.
thoughts?
Old Sep 18, 2022 | 07:58 AM
timinatorx92's Avatar
a mechanic that is familiar with evos can do the gear swap without fully removing the timing belt and messing up the timing. but the book for the cam gear swap would probably call for timing belt removal and install. so the labor is about right.
Old Sep 18, 2022 | 08:09 AM
Biggiesacks's Avatar
When was the last time the timing belt / balance shaft belt was replaced? If your past 50% service life, it would be a good time to just get the whole job done.
There is a filter element for the Mivec cam gear. Since you are replacing the gear, you will probably want to make sure that gets replaced too.
PN MD371660 reference found here:
https://partsouq.com/en/catalog/genu...&uid=121135&q=
Old Sep 21, 2022 | 09:20 PM
was only 2k miles ago lol. I’ll check out the filter, thanks!
ryanjafc
Aug 24, 2020 03:30 PM
tsitalon1
Jun 30, 2014 03:54 PM
overdrive1
May 15, 2014 09:52 AM
butte
Feb 23, 2014 10:22 PM
turbo speedy
Jun 23, 2010 08:24 AM
