one fan not working
Old Sep 23, 2022 | 03:44 PM
Stev-o-evo's Avatar
one fan not working
I checked the fuses they are both working one fan is working but one is not what should I do please help 🙏
Old Sep 23, 2022 | 04:08 PM
Which fan are you referring to? Theres only one stock rad fan
Old Sep 23, 2022 | 04:40 PM
Stev-o-evo's Avatar
It’s a mistsumosho radiator with two fans and the one fan is not working
I checked the fuses they’re both good I’m just not sure how to check the relays I don’t know what the omhs are supposed to omhn at. Thank you so much for your help sir
Old Sep 23, 2022 | 05:22 PM
Oh, i see. I went back & saw your pics & see the aftermarket rad w/the 2 fans. Does the fan spin freely? That could be the simple diagnosis. Maybe just a new motor needed? The other fan works! If the connection is proper its likely the fan motor failed.
Old Sep 26, 2022 | 07:56 AM
Stev-o-evo's Avatar
yeah it spins freely im thinking its the fan computer next to the fan
Old Sep 26, 2022 | 08:36 AM
bcollins92's Avatar
If you have a drill battery, you can test the fan to make sure its not bad. Just put a wire on each terminal in the connector and then on either terminal of the battery. More than likely it is your fan control module. Amazon sells them for like 26 bucks, I have one on my car and its been working good so far.
klutch814
Nov 4, 2018 07:19 PM
nor11384
May 11, 2018 07:52 PM
black_beauty
Jun 8, 2012 07:30 AM
03whitegsr
May 20, 2010 10:57 AM
woodc
May 20, 2005 05:03 AM
