Evo Sounds Like A Subaru
Old Oct 11, 2022 | 06:05 PM
steven121's Avatar
I tested this car as much as possible
Compression test 180 across the board
new spark plugs
swapped to a new cop system
injectors got cleaned and came out good
Car sounds horrible and felt on the manifold to see which cylinder is not firing
cylinders 2-4 were hot, cylinder 1 was cold on the manifold
cylinder 1 is not firing and not sure if its the pistons rings or a bent valve, but I assume a bent valve should not hold pressure right or can it but not allow the cylinder to fire properly
However cylinder 1 is too the touch on the exhaust manifold
Old Oct 11, 2022 | 07:25 PM
Not following your notes here. Am i reading this correctly?
Wouldnt a leak down test be the next step? The compression value of 180 is certainly way over the max allowable at 145 unless this motor is not built to stock specs?
Old Oct 12, 2022 | 06:32 AM
bcollins92's Avatar
If the compression is good across all cylinders, it would suggest your valves and rings are doing their job. Do you have plug and play adapters for your injectors? Give the wires a pull on the adapters on cylinder 1 to see if any of the pins have unseated themselves.
Old Oct 12, 2022 | 08:28 AM
ViciousLSD's Avatar
my car actually sounds like a subie while idling for a long time now. i know i'm running super lean (16-18) at idle and I havent found time to make adjustments.
Old Oct 12, 2022 | 11:10 AM
steven121's Avatar
that’s what I thought but I verified that each cylinder is making that amount of pressure
Old Oct 12, 2022 | 11:11 AM
steven121's Avatar
no they plug straight into the adapters. 1050cc fic low z injectors
Old Oct 12, 2022 | 11:14 AM
Chrispy0530's Avatar
I thought I had posted this morning, but guess it didn't go through when I hit reply.
If you haven't already, be sure to check the Injector Resistor Box. I had the same exact symptoms you had and the root cause was exactly that. Resistor Box was faulty.
Old Oct 20, 2022 | 07:30 PM
asugamilla's Avatar
Also check your MAF if you have one to ensure there are not fault codes associated with it.
After disconnecting mine and reconnecting it, my car sounded like it was a subaru.
After checking everything over, I checked if there any DTC's on EvoScan and sure enough there was one which came up
to do with the MAF. I promptly cleared it and the car was back to normal.
Anthony
Old Oct 20, 2022 | 07:38 PM
ViciousLSD's Avatar
I just got a code for the 1st time, about "o2 sensor stuck lean". I'll try to replace it and let you know
Jestersplay
Feb 4, 2021 08:03 AM
Wnbevo
Sep 17, 2017 12:30 AM
88888
Jun 9, 2015 08:49 AM
Evo3573
18
Dec 18, 2010 12:08 PM
nothere
Aug 10, 2008 06:53 AM
