Manley I beam vs carrillo pro h beams HELP
Old Nov 16, 2022 | 07:56 PM
krys88's Avatar
Hey guys, how many of you using Carrillo H beams on high hp evo? I am building spare motor and originally I wanted to go with Manley turbo tuff 300m with 625+ bolts. I know they are heavy and they are on back order for 3 months or more. So I am considering carrillo pro h beams rods with carr bolts. How strong are they? Carrillo's are lighter by around 100 grams per rod. Will rod weigh be noticeable on 900+whp ? Also will carrillo be ok with that power level. Look like everyone is using manley i beams including me on my old engine. Please help to choose. Aluminum is not an option. Thanks!
Old Nov 17, 2022 | 12:12 PM
Abacus's Avatar
Carrillo makes a nice rod. I've got them in both my engines. Lightweight but strong. One set is from 2007 / 800-1100hp for its life. Both have upgraded Carr bolts. Other set sees 500lb ft at 4000rpm.
150mm shows available
153mm is special order
156mm shows on backorder.
Old Nov 17, 2022 | 01:28 PM
krys88's Avatar
Thank you so much for your input. Yes the one I need is 150mm and they are available. How many miles do you have on engine that is from 2007? My current motor is 8 year old and over 25k miles on the street with wiseco pistons and manley I beam at around 700whp all its live. Still running great but I can see some blow by more than before so that's why I am building another motor so I can pull this one out and refresh. Thanks!
Old Nov 17, 2022 | 01:43 PM
Abacus's Avatar
25K hard miles.
RealStreet
Aug 24, 2012 10:31 AM
RealStreet
Aug 22, 2012 02:03 PM
Android4g63
47
Mar 11, 2012 05:27 PM
gt42r
74
Mar 7, 2012 12:46 PM
DeliriouS
18
Mar 13, 2010 05:51 AM
